10-23-2017, 04:20 PM | #16 |
Right now I have a single 5/8" bolt with a double nut on the end holding the stand on. I was planning on using 5/8" smooth bar with either a washer and cotter pins on each end or like you suggested some kind of locking pin.
I have an older brother that was a welder for over 40 years and took a forced early retirement due to some disabilities and that this would be a perfect little project for him to keep him busy. Believe me his welding skills are far better than mine. I'm going to get with him after I redesign it and see if he would be interested in building some. I put a 50+ hours in a 5 day work week and like my me time on weekends. I would rather him do it and make the money to help him out.
10-23-2017, 05:29 PM | #17 |
I'm on the fence on the center stand, but I sure would like to have a skid plate.
10-23-2017, 07:43 PM | #19 | |
10-24-2017, 08:59 AM | #21 | |
http://www.cscmotorcycles.com/TT250-...p/csc-1109.htm
10-24-2017, 02:25 PM | #22 |
Great idea.
My hawk was too low for the harbor freight motorcycle stand (the kind that you raise up with a pedal), and too low and heavy to get up onto a dirt bike stand easily, especially since the rear brake sticks out the bottom of the bike. This would have made changing the rear wheel and swingarm stuff a piece of cake. |
10-24-2017, 02:28 PM | #23 | |
I can confirm the skid plate from CSC fits the hawk, no modifications necessary I just powder coated mine: |
10-24-2017, 08:17 PM | #24 | |
2013 SSR XF-250 |
11-07-2017, 05:33 PM | #25 |
Update
Just an update. Working for a large construction company has its benefits. One of the steel fabricator contractors is working up a price on the skid plates. He has a computerized water jet cutter. Basically all I need to do is provide him with the CAD drawing and it can cut it out from there. It will also not be so plain Jane as it will have a few holes and slots in it just to help with ventilation and weight reduction. He can make all the cuts and make the bends for me then all I will need to fabricate is the center stand.(He's working on a price for that too but that will probably drive the cost up because its time consuming ) What I will probably do is have the center stand as a bolt on option to the skid plate. depending on the cost I will probably start with 20 and see how they sell.
11-08-2017, 03:10 PM | #26 |
I'm still waiting on quote, but to give you an idea of what the skid plate will look like.
11-08-2017, 03:28 PM | #27 |
Looks good....
If you bolt the centre stand to the plate then you could make the plate in alloy.. ..
11-08-2017, 03:38 PM | #28 |
I'm getting it price steel and aluminum. My plans is to do a bolt-on center stand with mounting holes and have it were it can be adjusted forward or backwards to balance the center load due to not every bike will have the same weight front and rear because of add-on like paniers.
11-08-2017, 05:25 PM | #29 |
if you bought a cheap chinese plasma cutter you couls make a under size cutting
patten.. clamp it to the alloy or steel run the plasma around it.... could cut the holes / slots .. ..
11-08-2017, 05:29 PM | #30 |
The water jet cutter is automated and will make a super clean cut. It will cut exactly what I have drawn including all the mounting holes once I do a mock up to get the exact locations. Once I have a completed set of plans it will be a matter of how many and what material at the push of a button.
