Old 08-23-2017, 11:03 AM   #46
Originally Posted by Border411 View Post
Bigweld....you need to stop using photobucket man! None of the photos show up because it says "please update your account to enable 3rd party hosting"! Use IMGUR....way easier and free.
and if you close or lose your account they disappear from here.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 08-23-2017, 08:48 PM   #47
mcwhorter-enforcer   mcwhorter-enforcer is offline
Old 08-23-2017, 08:49 PM   #48
[IMG][/IMG]
Old 08-23-2017, 08:50 PM   #49
The one where she is naked is what I have taken it back down too. I am adjusting the valves in the morning and wanted easier access to the battery.
Old 08-23-2017, 08:55 PM   #50
So here is a question...My motor does not look like the one on the Hawks. I does not have a drain plug on the side. It only has a drain plug in the dead center underneath the motor and it looks well made. I havent started the fluids yet, starting with the valves and moving forward. Spent almost 4 hours putting loc-tite on every bold and putting grease anywhere it would fit.lol. Heres the motor
Old 08-23-2017, 11:50 PM   #51
The Bashan is probably made by Bashan, although it is not the same engine, from what I understand, as the Storm, Brozz, or Shark. I think Bashan made your bike to go head to head with the Hawk, only they were able to get their bike EPA/DOT certified since they threw it on the same certificate as the Storm, Brozz and Shark even if they didn't use the same engine. They probably went slightly 'lower-rent' to make the Enforcer's (I don't mean that as an insult--really I don't) price point head to head with the Hawk. Their other 3 bikes are considered a slightly 'premium' bike, even with the oddball wheel sizes.
Your Bashan is, ironically, a superior Hawk to a Hawk!? Go figure...
Old 08-24-2017, 04:15 AM   #52
Makes sense, I will know more tomorrow when I change the oil. I just hope the screen doest fall out and go in the pan
Old 08-24-2017, 07:28 AM   #53
goat67   goat67 is offline
goat67's Avatar
It looks like the engine is non Counter Balanced?
My Brozz has the Counter balanced Engine.
2016 Brozz
Old 08-24-2017, 08:09 AM   #54
Border411   Border411 is offline
HOLY CRAP!!! THAT HAS A COUNTER BALANCED ENGINE!!!! That must be new as it didnt have it before. See the bump on the top left looking at the left side photo....
Old 08-24-2017, 09:18 AM   #55
Merlin   Merlin is offline
Look closer. I don't see a balance shaft on mcwhorter-enforcer's engine. Check out this counter balanced engine pic with the gray cooling fins on the bottom front of the engine and you will see the difference.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 08-24-2017, 09:24 AM   #56
Ah...I see it now. Damn!
Old 08-24-2017, 09:37 AM   #57
I wouldn't want you to buy this bike thinking you had bought a balanced shaft engine. We look out for each other around here.
Bashan Blaze
Old 08-24-2017, 09:58 AM   #58
Thanks man! Still my #1 choice if I don't buy used Japanese. Find a 1995 DR 350 with 3k miles for $2100 near me. Only if I had the money ready to go!
Old 08-24-2017, 10:02 AM   #59
That's a CG motor like others. The other oil drain is the big-a$$ cap behind your shift lever. It has the oil screen inside.
Old 08-24-2017, 10:23 PM   #60
It's alive!!! It's alive!!!
So I didn't adjust the valves first. My buddy who is a motorcycle mechanic stopped by as I was pulling the valve cover. He said do not...and said it again...do not adjust the valves first. At 500miles adjust them, so I didn't. Lol.
Rode it around the block a few times and shut it down then road it around the block again.
Runs great, carb needs some tweaking, but the ride was amazing. As soon as my documents come I will take it for a good ride but for the next few days it will just be around the neighborhood.
The cons... gas gauge doesn't work, tail light blew almost immediately so I will have to replace it before I take it to get inspected.
bashan, enforcer
