Old 07-10-2017, 06:48 AM   #16
PhildoScaggins   PhildoScaggins is offline
Originally Posted by NnuttHowz3 View Post
That is the exhaust I have on my bike. I didn't attempt to mount it on the kick stand side but it does want to go that way. We heated mine up and bent it to go the other way and changed the bend a little to match these bikes
Thanks nutt! How hard was it to bend once heated? I tried bending mine with a vice after I heated it and didn't have much luck. It seems much easier than relocating the kickstand though!
Old 07-11-2017, 02:14 PM   #17
Not So Mild   Not So Mild is offline
We ended up welding my factory exhaust back together and to the frame of the bike. I went a little easier on the bike this weekend, but definitely tested the limits. I would say that if you are worried about this happening and you are able to, just reinforce the welds a little bit. I ended up ordering a new can for my exhaust (similar to prismways). Anyways should be in this week. I needed a shorter can for my bike so figured this was a good excuse to buy one.
Old 07-12-2017, 02:15 PM   #18
prismways   prismways is offline
prismways's Avatar
I don't think you will be disappointed with the new exhaust.
Old 07-13-2017, 01:53 PM   #19
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
I've been thinking about doing a underbelly exhaust on mine. You wanna sell it?
Originally Posted by PhildoScaggins View Post
So I pretty much ruined the exhaust I bought to get it on my bike, looks like crap.
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 07-14-2017, 10:16 AM   #20
Want to trade? It would need a bit of adjustment to fit your bike probably. It's kinda loud, but deff lets the bike breathe better than the stock. Also do you have a link to a good set of engine bolts? I went through my second set after about 500mi.
Old 07-19-2017, 05:53 PM   #21
If my exhaust was still stock I would, but I hacked it apart and gutted it. The guys I ride with say my bike sounds like a chainsaw. I couldn't in clear conscience pawn that cobbled together POS on you. As for the motor mount bolts, I ended up using these;
https://www.mcmaster.com/#91257a118/=18kj7a2
I had ordered some 8mm Allen head screws but the threads didn't clear the edge of the motor mounts. IIRC, a 13mm wrench will work on a 5/16" bolt. I packed the bolt holes with marine grease before bolting everything together. I've put almost 1000 miles on the bike since the last repair without incident, but I'm having issues with chain tension now.
Old 07-19-2017, 11:20 PM   #22
martim   martim is offline
Razz Exhaust Recommendation for 125CC Vader
Hi Guys,
New to the site...any recs on exhaust, carburator and airfilter for these bikes?
Mine is identical to the white one in the photos below.
Any help is greatly appreciated. Thanks,
Old 07-21-2017, 04:19 PM   #23
NnuttHowz3   NnuttHowz3 is offline
Originally Posted by martim View Post
Hi Guys,
Hey Martim,
Just helped you on Amazon. Make a new thread here post some pictures of your new ride and post your questions there.it will be much easier for answers vs all the posts you have made in these threads!
Old 07-21-2017, 04:30 PM   #24
Sorry missed this earlier did you get it?
We used a vice and a metal punch inserted into the exhaust and bent it, slowly.
Old 07-23-2017, 06:47 AM   #25
Lots of broken
So over the course of two days I broke a lot. This happened at about 1400 miles
So I decided to put my original exhaust back on as a straight pipe (remember that broke too). About 40 miles later I hear some exhaust noise and this happened
Oh boy.
So I figured since my bike was gonna be out of commission till I get that broken bolt removed I figured I'd take on the carb in the meantime. I took off the emissions junk and what do I find?
So I guess I've got my work cut out for me.
Old 07-23-2017, 08:33 AM   #26
Oh boy.
Damn dood! you've got worse luck than me! Why is your engine eat up with rust? Don't use an easy out extractor to remove the studs, and don't use a helicoil for the repair. Drill out the studs with a silicon carbide bit and use a threaded insert like Acme, Keensert, keysert, etc.
Old 07-23-2017, 09:43 AM   #27
I think it looks like rust, it's covered in dirt and grime. Maybe a tiny bit of rust from riding in the rain/not washing it. Coastal salt air maybe?
So an easyout sounds like a bad idea? It's all I got at the moment.
Old 07-23-2017, 10:42 AM   #28
The only thing an easy out is good for is breaking off in an engine block. Then you have the drama of trying to drill out a bit that's harder than Chinese calculus. I've had bad experiences with easy outs, especially working in confined spaces. I prefer to use a centering punch and silicon carbide drill bits.
Old 07-23-2017, 11:33 AM   #29
Mudflap   Mudflap is offline
The most reliable way I've found to remove a broken stud is to place a nut over it and weld through the center. Has worked every time I've done it. Quick and easy.
Old 07-23-2017, 12:58 PM   #30
MOTOXtreme   MOTOXtreme is offline
My opinion, do NOT remove the factory threads unless ALL else fails. Id drill it out with about a 1/8 bit (quality bit, not some crap bit) and then heat up the area AROUND the stud (not applying heat to the stud directly if you can avoid it ) , spray liquid wrench on it and then you should be able to remove it with the tip of the easy out, tapping in a cheap Phillips driver or whatever.
Brian
Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com
"Imagination is more important that knowledge" Albert Einstein
