Old 05-10-2017, 04:51 PM   #1
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
Motor mount bolts replaced... Don't fear the Reaper
The bike has had some vibration when decelerating thru 6k-5k rpm range. It got progressively worse on the 128 mile ride today. I started checking the bike out after it had cooled down. The only thing loose was the chain, like "I'm surprised it didn't fly off the sprocket" loose. The swing arm bolts were tight, so I decided to pull the front sprocket cover and found the problem. The head sheared off the lower motor mount bolt. Story of my life
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 05-10-2017, 05:06 PM   #2
iparks81   iparks81 is offline
Wow! Im'a pull the cover off mine and check this tonight! are you able to find a replacement? does the motor "rock" at all if you push pull on it in the frame?
best of luck!
Old 05-10-2017, 07:14 PM   #3
I ordered some replacement bolts from McMaster-Carr. The engine is hanging loose at the top motor mount. I'm gonna replace both bolts and use fender washers at both ends.
Old 05-10-2017, 11:49 PM   #4
prismways   prismways is offline
prismways's Avatar
Holy crap. Good thing you weren't injured. I will consider changing mine out too!
What was the size and type of bolts did you order?
Old 05-11-2017, 08:42 AM   #5
lildew   lildew is offline
for the bolts on the Vader it is 4 1/2" by 5/16 for the bottom and 5 1/2" for the top engine mount bolt.
Old 05-11-2017, 11:36 AM   #6
That's odd that a Chinese bike would have SAE fasteners. The monster's bolts are 8mm x 1.25mm x 120mm. I ordered 130mm length to make up for the thickness of the fender washers.
I've been doing a little reading on bolt failure and this is common when a bolt has to hold a part in place as well as setting it's location. If shims were used to align the motor and mounting bracket, this probably wouldn't have happened. Isolating engine vibrations with bushings in the mounting brackets would probably have prevented the break as well.
Old 05-11-2017, 12:01 PM   #7
The old timers on normal bikes have also warned about out of box loose mount bolts too.
Old 05-11-2017, 04:21 PM   #8
they are metric but i used the 5/16 size.
Old 05-11-2017, 05:10 PM   #9
Looks like it was WAY over-tightened at the factory. These motor mounts on most CB's only take about 18-22 ft lbs, depending on bolt thickness. Having them all torqued evenly is far more important than "bear down tight".
Better check the rest. On Mrs. 2LZ TT250, it had a bad vibration and I found the motor mounts in all different torques. I evened them up and the vibe went away.
Old 05-11-2017, 11:46 PM   #10
ben2go   ben2go is offline
Over torquing a bolt causes it to stretch. Vibrations, plus torque from the engine trying to move, will cause the mounting bolts to break like this.
Old 05-12-2017, 02:33 AM   #11
Bruce's   Bruce's is offline
purchasing anything because it was 1/3 the cost of an original is also the reason bolts break like this .Instead of real butter ,they use the I can't believe it's not butter bolts to sell at the price point that gets them out the door .
Old 05-13-2017, 05:22 PM   #12
I've bought a lotta crap from China, with emphasis on "crap". It's to be expected. I wasn't surprised that the naugabutter bolts were pitted with rust, like the original gas tank. I guess their parts department is on a flood plain. There's also too much side play in the mounts. I'm not gonna bother buying real shims, I've got a coupla PBR cans that will work just as well.
Old 05-13-2017, 05:33 PM   #13
prismways's Avatar
not sure what all these acrononyms and jargon is about, but interested to see how you secure the motor and mounts.
Old 05-13-2017, 09:56 PM   #14
sshevie   sshevie is offline
Lol real pbr can shims on a China bike.....here hold mah beer!!!! I do love the way we all jerry rig our CBS to make them work
Old 05-13-2017, 10:55 PM   #15
jsumd   jsumd is offline
jsumd's Avatar
Well damn! At least you weren't hurt. I'll have to keep an eye on mine.
2002 Harley Davidson XL883R
2012 Yamaha FZ6
2022 Hawk 250
2002 Yamaha R6 *sold*
Vader 125cc *sold after owning for many years*
1997 Jeep Wrangler *sold due to frame rot*
