Old 04-20-2017, 09:12 AM   #1
barnold   barnold is offline
Falcon 150
I just got a new to me Falcon 150 auto. Is there a list of things peeps have done to this machine, known issues/performance. Like carb, airbox, chain/sprocket, cvt clutch?
Thanks
Old 04-20-2017, 12:26 PM   #2
Welcome!
Please start with pics and perhaps we can guide you from there.
Old 04-20-2017, 12:28 PM   #3
just have to figure out how
Old 04-20-2017, 12:52 PM   #4
Use Google search
Try this
https://www.google.com/webhp?client=...+post+pictures
Old 04-21-2017, 08:33 AM   #5
Falcon 150
Old 04-23-2017, 08:30 PM   #6
Please show us the rear axle as well; it matters.
Old 04-24-2017, 07:56 AM   #7
I found this which could help: http://www.kazumausaonline.com/kazum...-c-228_31.html
Old 04-24-2017, 09:05 AM   #8
I will have my post a pic of the rear axle as soon as i can.
Old 05-01-2017, 01:29 PM   #10
Ok, your quad appears to be equipped with a planetary reverse device, which is bolted to the rear of the case. For those who are unfamiliar with this engine, it's a scooter design, which means the output shaft on the rear of the case is designed to accept a rear scooter wheel. This quad has a planetary device bolted to that section and the output shaft directly drives the device. I highly recommend that it be drained, flushed with a little Varsol and filled with gear oil (don't overfill).
The rear section of the case has gears in it as well, which served as the final drive in scooter configuration. Look at the left side of the very back of the case and you'll see drain and fill plugs there as well. I use Castrol Syntec 75W90, because I'm looking to protect the gears as much as possible. Same goes for the planetary reverse device.
The engine can take plain 10W30, since it's not using a wet clutch. I use synthetic there as well, because I'm trying to coax every last pony out of it.
Old 05-01-2017, 02:34 PM   #11
Thank-you for that info.
Old 05-01-2017, 06:02 PM   #12
Can I change the sprocket and chain if i want to, also is there clutch cleaning to do, I am a snowmobile guy, so I understand cvts. Should I replace springs in the clutch?
