Old 03-08-2017, 12:02 AM   #46
JMM   JMM is offline
Originally Posted by oldscooter View Post
My manual says 90 also. Premium here is 92, so I got a 5 gallon can of that. With the mileage it gets, that should be plenty and only costs a bit more.
The Mobil station near me has 87/89/93. So I filled it with 93 today. We will see how she runs with it
Old 03-08-2017, 07:51 AM   #47
I think even if you ran the middle grade 89 you would be okay. I run 89 and 93 ethanol free gas. I not sure how good gas is in your area but here we have pretty good gas. No corn squeezing in my gas. lol
2020 Kawasaki Vulcan S
Old 03-08-2017, 09:34 AM   #48
Azhule   Azhule is offline
I run 85 to 87 in my Bashan WILL that has a 9.0:1 compression ratio...
And here is what the Emissions plate reads on this bike... it should be noted (again and again...) that it has the generalization of what "Octane" number to use... testing of "Octane" numbers is different depending on where you are in the world...
Where our bikes are made (over in China), they like to use RON (Research Octane Number) as their "Octane" testing and numbers... in North America, we will see it as AKI (Anti-Knock Index) as the "Octane" testing and numbers...
85 AKI is about the same as 90 RON... and unless you slapped a high compression piston in, or your bike is pinging under load (trust me... it shouldn't with only a 8.7:1 compression ratio)... you are doing your bike and wallet no favors by using anything higher then regular fuel
https://en.wikipedia.org/wiki/Octane_rating
Old 03-08-2017, 09:41 AM   #49
JMM   JMM is offline
Thanks for the clarification. Sounds good
Old 03-08-2017, 11:09 AM   #50
JMM   JMM is offline
So morning update. It's overcast till after noon some time. I'm headed to try to register it. Wish me luck
Cold starts are a PITA to get it to idle. On choke, cold start, doesn't want to idle by itself without partial throttle help. Once warm, it idled fine off choke. But when it's cold, I can mess with the idle screw to get it to idle without throttle, but the rpms jump once warmed, and I have to mess with the idle screw to lower it down. Thinking maybe the bigger jet or new carb might help elevate this problem.
Thoughts?
Old 03-08-2017, 11:32 AM   #51
Merlin   Merlin is offline
Thoughts?
Try a larger main jet. Sounds like your running lean.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 03-08-2017, 11:42 AM   #52
mjstef   mjstef is offline
Actually i run premium ONLY because it's ethanol free.....
Old 03-08-2017, 12:37 PM   #53
JMM   JMM is offline
That's what I was thinking. I know they run lean from the get go. And the air box mod (if it did anything), didn't make it run any less lean. I got the Jets in yesterday. I'll give it a shot.
What's your thoughts on size, put the 110, 115 in?
Thanks
Old 03-08-2017, 03:12 PM   #54
Ariel Red Hunter's Avatar
What's your thoughts on size, put the 110, 155 in?
Thanks
155 sounds too rich to me. ARH
Old 03-08-2017, 03:40 PM   #55
Thanks
Jetting will help but these don't have a high idle on choke. It's a pretty simple carb.
Old 03-08-2017, 03:49 PM   #56
ben2go   ben2go is offline
The main jet doesn't affect idle. The pilot jet controls idle along with the enricher (choke) when it's on. I would step up the pilot jet two sizes.
Old 03-08-2017, 05:54 PM   #57
JMM   JMM is offline
Yeah, you aren't kidding. Haha. 115
Old 03-08-2017, 05:56 PM   #58
JMM   JMM is offline
What size is the pilot jet?
Old 03-08-2017, 06:45 PM   #59
Good to see that you have a sense of humor. ......ARH
Old 03-08-2017, 07:08 PM   #60
hertz9753's Avatar
http://articles.superhunky.com/4/52
I thought you had one of those...
