Old 01-16-2017, 07:55 AM   #76
Huck369   Huck369 is offline
Huck369's Avatar
I plan to start running some premium fuel thru it every couple tanks to help keep the injector clean
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 01-16-2017, 12:46 PM   #77
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
To the best of my knowledge, I don't believe that this has been a problem with our carbureted friends. I wonder if the tight exhaust valves are causing a brief lean condition that the EFI isn't adjusting to in time?
I don´t know about the other carbureted friends (at Colombia), but here at Argentina the cheapest fuel has 95 octanes, while the expensive one has 98.
Perhaps that´s why we -usually- doesn´t suffer the stalling issue here.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 01-16-2017, 01:26 PM   #78
Huck369's Avatar
Rode out to lunch just now...died 3 times on me....so....still not fixed......
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 01-16-2017, 01:31 PM   #79
Azhule   Azhule is offline
Top Tier Fuel or a good Fuel System Cleaner (usually something with "PEA" like Techron) would be better than going with the wrong grade of fuel... only go with a higher grade of fuel if you are having 'detonation/pinging issues'
Sorry if I misunderstood what you are saying, but from what I read, it sounds like you are going to use the wrong grade of fuel thinking it will clean better
Old 01-17-2017, 10:41 AM   #80
Having two RX3's now, it's amazing the things one notices.
My white one, I have perfectly, analy done. Everything is tight, lubed, connected, adjusted....and sometimes (rarely) it stalls.
The blue one I just got from my brother? Just this weekend I found the valves were out of adjustment, BOTH battery cables were completely loose, nothing was adjusted correctly and the right filter screen was loose and dripping....and it runs perfectly and never has stalled on him once. Go figure....
Old 01-17-2017, 02:07 PM   #81
Grin
Great! Now you know what should do with the white one!
______________
Old 01-17-2017, 02:14 PM   #82
Huck369's Avatar
So.....I shouldn't baby it, is what you're saying
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 01-17-2017, 08:49 PM   #83
Jay In Milpitas's Avatar
Since the AJP is also Zongulated, how does it compare?
Old 01-17-2017, 10:30 PM   #84
Huck369's Avatar
My AJP is the PR4, so it doesn't have the NC250 motor like the RX-3 has, but it is top shelf suspension and great build quality....I'll have to get some real trail time on it to give a good opinion, the weather hasn't been cooperating since I bought the PR4......hoping to hit the trAils this weekend ....
Huck
2013 Honda NC700X
2016 AJP PR4
2022 Templar X 250
AMA Life Member
Old 01-17-2017, 10:34 PM   #85
We have a word of the day
Zongulated
Old 01-17-2017, 11:03 PM   #86
My mistake. I disZongulize you.
Old 01-18-2017, 07:46 AM   #87
madsocial   madsocial is offline
madsocial's Avatar
I already do that and I use the Lucas oil additives. So, I'll try the fuel pump first and go from there.
Cheers!
Rania aka madsocial
2016 Zongshen RX3 (CSC Cyclone)
Pay it Forward!
Old 01-18-2017, 07:48 AM   #88
madsocial's Avatar
Cheers!
Rania aka madsocial
Pay it Forward!
Old 01-18-2017, 10:48 AM   #89
I still think it has to do with the IAC not keeping up with the sudden closed-throttle demand on occasion. What's causing it not to react is another story. Is it the IAC itself (sticky pintel?) or a sensor or ECM not feeding it the proper info in time?
Old 01-18-2017, 12:03 PM   #90
pepperami   pepperami is offline
Another one who`s bike stalls.
I`ve changed my riding style when I`m on my RX3.
I find mine will stall sometimes when rolling off the throttle after a hard blast at higher revs.
So now as I come down the revs/gears, I blip the throttle once or twice.
Not a cure but at least I don`t end up at the side of the road trying to start it again
I wonder if these bikes are running to lean and the fuel injection/electronic wizardry cant cope at times???
This is who I am, deal with it
