Old 10-10-2016, 07:38 PM   #1
ballinparlay   ballinparlay is offline
Valve Ticking/Adjustment Clearance Hawk
Ive heard everything this side of the Mississippi on the correct valve clearance for the Hawk 250. Mine came with zero clearance on the intake and exhaust so I adjusted them today after about 500 miles to .006 on the intake and .007 for exhaust. The bike starts up better than ever but the ticking noise is pretty loud. Ive heard that you want some ticking, but I guess how much is too much? Very arbitrary without a decimal meter and legitimate science, now that Ive made this question as complicated as possible, what do yall's adjusted valves sounds like and is the sound prevalent even when accelerating and/or at higher RPMs?
Old 10-10-2016, 08:01 PM   #2
humanbeing's Avatar
Originally Posted by ballinparlay View Post
...adjusted them today after about 500 miles to .006 on the intake and .007 for exhaust..
Too wide!!! http://www.chinariders.net/showpost....78&postcount=2 | Honda shop manual https://josemaco.files.wordpress.com...h-62ktjam5.pdf of that design
Old 10-10-2016, 08:45 PM   #3
Republic   Republic is offline
My valves had zero clearance, I adjusted them both to .006. They are silent when cold but when the engine gets warm they are noticeable. Mine don't sound any louder than those I've watched in various Hawk videos on youtube, so I'm guessing I'm ok.
Before I adjusted them, the bike was very hard to start, now it starts immediately.
Old 10-10-2016, 09:43 PM   #4
ben2go   ben2go is offline
The problems come when the ticking stops.
Old 10-11-2016, 10:21 AM   #5
Ariel Red Hunter's Avatar
That's pretty loose. I think you will like .002 and .004, or .003 and .005 better.
Old 10-11-2016, 06:38 PM   #6
I re-adjusted to .002 and .003, it sounds much better and still starts easy as pie. Thanks for the info, guys
Old 10-12-2016, 11:37 AM   #7
DGF   DGF is offline
Complete rookie here so please excuse me if I'm missing the obvious, but why is the exhaust lash set higher than the intake? Would it be ok to set both at say .004"?
Dan
Old 10-12-2016, 11:52 AM   #8
Excellent question, Dan. It's common to give the exhaust side a little more expansion room, due to the extra heat.
Old 06-26-2017, 10:48 AM   #9
wamey   wamey is offline
wamey's Avatar
Resurrecting an old thread, have there been any developments on the hawk valve clearances or is the RPS spec good? I see the manual lists them as 0.05mm, though I like the sound of ARH's recommendation of 0.03mm intake and 0.05mm exhaust better:
Old 06-26-2017, 12:03 PM   #10
It depends; are you looking for maximum performance or maximum longevity? I steer towards longevity and use the same spec for both valves. Tappy valves are happy valves.
Old 06-26-2017, 08:25 PM   #11
pistolclass's Avatar
40 psi rear......??? seems a little high. what do others run? I run 35 psi.
Old 06-27-2017, 08:31 AM   #12
XDoubleXA   XDoubleXA is offline
XDoubleXA's Avatar
I run 32psi front, and back.
Old 06-27-2017, 10:07 AM   #13
I set both at .05mm or .002".
2020 Kawasaki Vulcan S
Old 06-27-2017, 10:32 AM   #14
Mudflap   Mudflap is offline
Valve lash on CG engines increases as the engine heats up. If the valves are closed well enough to get it started you're not going to burn a valve. Some owners and shop manuals for CG engines call for .002" for both valves. Some call for .002" intake and .003" exhaust. The Honda shop manual for the original CG 125 calls for .003" on both valves. I use .002" on all my CG engines to keep them as quiet as possible but any clearance up to .005" shouldn't be a problem except for a bit of noise.
Old 06-27-2017, 01:10 PM   #15
wamey's Avatar
0.05mm it is! Thanks all!
Also I run at 30 front 32 rear, no particular reason other than 40 is too much in my opinion.
