Old 07-28-2016, 07:48 PM   #1
Mikuni drain hose wet but not dripping
I never paid any attention to drain hoses in the past, is it normal for them to be wet with fuel but no noticeable dripping. I opened up the drain screw some and held the end of the hose up to see where the fuel level in the carb is and it appears to be almost level with the top of the bowl.
Old 07-28-2016, 09:25 PM   #2
w0ss   w0ss is offline
funny you mention that, I saw the same on mine and just assumed it was normal. I never see it leaking but almost looks like it's weeping or something.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-28-2016, 09:50 PM   #3
I wonder if it is just fumes condensing? If a few more say they experience the same thing, it's a safe bet that's exactly what's happening.
Old 07-30-2016, 01:33 PM   #4
Ariel Red Hunter's Avatar
Yes it is normal. When the bike goes over a bump, the float tends to flutter, letting in too much fuel. The fuel bowl is small, so as to prevent sloshing. A bigger float bowl would obviate the need for an overflow drain, but experience has shown that losing a little fuel from the over flow is better than having a large amount of fuel sloshing around in the float bowl, upsetting the fuel delivery. The original carburetor this one (and the Mikuni) is derived from had a totally different float and needle system that was pretty impervious to flutter. But costs a lot more to make.
Old 07-30-2016, 07:23 PM   #5
Normal when going over bumps, but, I'm asking if it is normal when parked?
I'm also curious at what level should the fuel be? As I stated earlier, mine is about even with the top of the bowel.
Old 07-31-2016, 07:29 AM   #6
Normal when parked? Only for a few seconds. The bike is off of vertical when on the side stand. Yes, the fuel level is very high all the time. That's one of the reasons you should turn off the fuel when parking the bike. A little hint ~ If you turn off the fuel before you shut off the engine, it should not drip.
Old 07-31-2016, 02:29 PM   #7
jct842   jct842 is offline
Leaks..........probably not in this case but I have had and others also, a leak that is so little that it doesn"t drip but you can smell it in the garage and will empty the gas tank if left alone by itself.
Old 08-01-2016, 06:21 PM   #8
Hmmn. This has happened to you with the gas shut off? If so, it is a defective petcock. I have read elsewhere about carb bowl boiling from proximity to hot exhaust pipe. This won't answer the problem of emtying the gas tank. If it is really emptying the gas tank, take out the oil dipstick and smell it for a gasoline odor. If you smell gasoline, don't start the engine. Change the oil before riding again.
Old 08-03-2016, 08:43 AM   #9
Mikuni drain hose
A possible reason for Mikuni's to have wet ends on the drain hose, and smell up the garage with gas smells is if the float level is too high. You have to be super careful when changing jets to not in-advertently bend the float arm just that little bit to over fuel the float bowl. When you turn the carb upside down with the float bowl off, measure from the machined ridge on the carb body to the farthest point on the float. Should be between .6 and .66 inch. The little metal plate that touches the needle is where you adjust float height. Take the float out in order to bend the tab. These float and needle and seat parts are very delicate, so be careful.
Old 08-03-2016, 08:49 AM   #10
mtiberio   mtiberio is offline
mtiberio's Avatar
ethanol changes the specific gravity of fuel, and some floats needs to be lighter so they float with more force and seal the float valve better...
Old 08-03-2016, 11:17 AM   #11
Interesting! I hadn't thought of that.
Old 08-03-2016, 11:42 AM   #12
Me neither. But I would run non-ethenol 90 octane, which is easily found around here.
Old 08-03-2016, 02:07 PM   #13
mtiberio's Avatar
I deal a lot with antique moto guzzis, and we find the lighter float trick works well on 40 year old carbs...
Old 08-04-2016, 02:27 PM   #14
Yes, and the DellOrto is another great carburetor.
