06-28-2016, 06:42 AM | #1 |
Hawk 250 jets
Hawk 250, mikunni carb,
if I remove cat, what jets will I likely need to go to? I'm mostly on street. |
06-28-2016, 09:17 AM | #2 |
Hard for anyone to narrow things down for you without knowing your specific altitude
06-28-2016, 11:23 AM | #3 |
Need to know if you opened up the airbox and also altitude you plan on riding at before I could even begin to recommend jet size.
06-28-2016, 12:44 PM | #4 |
Has been opened up considerably. Still retains stock style filter. It could easily be modified further accordingly. I'm at about 600' , Nashville TN area. Won't likely get much higher.
I've got the pipe and welder ready. |
06-28-2016, 01:58 PM | #5 |
I'm running a 117.5 main and 30 pilot jet with an aftermarket air pod intake. I'm running a little rich. I'm at about 800 elevation. with cat removed, I might be in a little better shape. I'd stick with the 115/30 at first and adjust from there.
06-28-2016, 04:18 PM | #6 |
Thnx. I'll double check what I have. Pretty sure it's what ever most commonly recommended
06-28-2016, 04:25 PM | #7 |
I have a 130/27.5(down from a 30) and I have a new exhaust and pod filter. Still not running perfect for me. I think each engine is different and you will get slightly different answers. Also mileage matters. I am just under 500 miles so fully broken in yet.
06-29-2016, 10:21 AM | #8 |
rally good point. I'm at about 750 miles now and it keeps improving. I was riding with Mark on some N.GA mountains and his hawk was maintaining on uphill grades better than mine.
06-29-2016, 10:33 AM | #9 |
115/25 works well with the nitrohead racing muffler (short wide header w/out muffler but a flute insert), 30 is a little rich, perhaps 27 would be ideal.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
