Old 05-24-2016, 08:55 PM   #31
newrider93   newrider93 is offline
newrider93's Avatar
I also solved the fender issue. Pushing the forks down to flush and adding fork oil stiffened up the suspension so the fender doesn't hit the tire. You can check out my video on that on my youtube channel.
My YouTube channel where you can check out my hawk and other cool stuff:
https://www.youtube.com/c/Andrew93
newrider93 AKA Andrew93
Old 05-28-2016, 02:32 PM   #32
newrider93's Avatar
Hawk Luggage
Hawk Luggage Video
Old 05-30-2016, 06:48 PM   #33
paulesmann   paulesmann is offline
paulesmann's Avatar
So how do you change the hawk's fork oil? Is it as easy as changing the motor oil?
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 05-30-2016, 07:11 PM   #34
newrider93's Avatar
Really easy. Remove the Allen bolt from the bottom of the fork and let oil drain out. Once empty replace bolt and take off the bolt on top of fork. Measure your fork oil out to appropriate amount and pour into fork. Then replace bolt. Super simple.
Old 05-31-2016, 03:41 AM   #35
paulesmann's Avatar
Nice, thanks man!! Type of fork oil important? Also how much would you suggest for a 220 pounder riding mostly on the road(who really hates bumps and pot-holes)
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 05-31-2016, 12:33 PM   #36
newrider93's Avatar
You could start with 150ml and see how you like the stiffness of the forks. If you want it stiffer you can always add more.
Old 05-31-2016, 06:34 PM   #37
I used 180ml of 10w fork oil in each fork, I think 150 isn't enough.
