Thread Tools Display Modes
Old 05-01-2016, 08:55 AM   #1
cheesy   cheesy is online now
cheesy's Avatar
Down Came The Shed
The new larger shed has been ordered, with tentative delivery scheduled May 16th. So, it's time to get cracking on the old one.
While cleaning it out, I found these little b*st*rds making short work of the lumber I stored in the shed.
Doors are off. Time to get serious.
One of the tools for the job, my 25 year old Sawzall. Also, an 8lb BFH, the Jeep and the JD.
Time to rock n' roll.
That didn't work so well. Missed a stud. Moved the shed about 3' while Mrs. C split a gut.
Next try did the trick. Set the Jeep up ninety degrees to the previous pull and gave a yank. However, it started raining about this point.
Now the hard work starts. Did I mention it was raining.
The only real casualty in the whole operation was the trash can in the above pic. The shed rolled over before splitting apart and hit the can. I spent the rest of the morning busting up stuff into smaller sections and dragging those with the JD to a future bonfire site. Need to cut up the floor today then start site prep next weekend.
I'll need the week to recover.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 05-02-2016, 09:49 AM   #2
Nice demo! That's a great way to have fun with a Jeep!
Old 05-02-2016, 11:04 AM   #3
Nice demo work!
Are those termites? Gross!
Old 05-02-2016, 11:39 AM   #4
Sport Rider's Avatar
I woulda just set it on fire.
Old 05-02-2016, 11:52 AM   #5
Razz
hmmm, when I was a kid I had a MUCH smaller ant farm
Old 05-03-2016, 01:14 AM   #6
cheesy's Avatar
I gave that some thought but figured once the big blue spruce trees over the shed went up in flames and then, in turn, took out the power lines, there'd be more people than just Mrs. C PO'ed at me.
Doc-Too cold here for termites. These were Carpenter Ants.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-04-2016, 08:21 AM   #7
Stoneman   Stoneman is offline
Looks like you have my sawzall! Ive had the same one since the early 70,s Used it in the masonry trade cutting holes in roofs. built to last!
Old 05-04-2016, 09:48 AM   #8
cheesy's Avatar
Bought new in 1991. Back then, I was a new hire at an outfit that delivered and installed dry cleaning equipment. One of my first jobs was to replace a washer and we found the hold down nuts rusted beyond removal with a wrench of any sort, so the 'experienced' busts out a hacksaw and starts going at it. I just said "Nope" to myself and told the guy I'd be back in a few minutes. He got a little pissy(big bosses kid) and I gave him the finger. I wandered to the Ace Hardware next door and came back with that Sawzall. I knocked out the other three hold downs before junior finished the first one.
The dry cleaning equipment company taught me that the grass is brown on both sides of the fence and shortly went back to the job I'd left. But not before I broke junior's nose in front of his Dad.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-10-2016, 08:25 AM   #9
cheesy's Avatar
Prepping the site for the new shed. The install got moved back a week, so I have a bit more time to get things ready.
Spec for the new shed calls for the site to be within 6" of level. The 14' x 14' pad for the shed was 13" out, hence the short wall. All that is left to do, if it ever stops raining, is to fill with gravel and compact.
More tools of the trade. A small, easy to handle 20v Dewalt 1/2" drill and the 'Beast', a 36v Bosch 1/2" wrist snapper.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-10-2016, 10:33 AM   #10
That Bosch looks like it should come with an arm brace!
Old 05-10-2016, 01:18 PM   #11
cheesy's Avatar
It has an extra handle but I never think to use it.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-11-2016, 01:25 AM   #12
36 volt! Wow!
Are you using tie-backs or angle bracing in your retaining wall?
Old 05-11-2016, 07:10 AM   #13
cheesy's Avatar
36 volt! Wow!
As I'm making this up as I go, there are one dozen 36" pieces of half inch rebar driven in through the timbers with two in each corner. Hence the wrist snapper with the extension. There are almost two hundred 3 1/2" #10 deck screws holding things together. The timbers are set below grade on compacted gravel.
Planning on the first load of grade 8 gravel fill this afternoon, with the second tomorrow. Then renting a compactor over the weekend.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-14-2016, 05:22 PM   #14
cheesy's Avatar
Ready for the shed.
My son in law, who spent his youth building houses with his grandpa, said I wouldn't need more than 1.5 yds of material.
You are looking at 3.25 yds of compacted grade 8 stone that I moved by my lonesome. Mrs. C helped with the leveling of one load, but that was it.
That little rental compactor was the catsass for this job.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 05-14-2016, 05:57 PM   #15
Bruce's   Bruce's is offline
That looks like some nice work .Thats a nice size plate tamper ,mine is a little larger but way heavier which is a problem when you want to move it somewhere else .I don't see a water hose though ,you have been wetting it down as you go right ?
