Old 04-27-2016, 09:35 PM   #1
mq1991   mq1991 is offline
Better Front Brakes for the Hawk?
Does anyone know of some better / replacement pads for the front brake on the Hawk?
My rear brake is awesome, but my front brake needs ALOT of force applied to slow the bike down.
Thanks guys!
Old 04-28-2016, 03:20 AM   #2
humanbeing's Avatar
[For typical on/off chonda] https://item.taobao.com/item.htm?id=42455912424
Copmared http://www.chinamomt.com/product.php (the stamped model...) & http://ebcbrakes.com/Assets/ecatalog...catalogue.html We get the following(s) : FA056 (Circular) | FA165 (Hooked) | FA086
Name brand product that suits ur taste can found by those "EBC#"...
Braided stainless steel brake line is a good upgrade...
Old 04-28-2016, 08:11 AM   #3
chuck   chuck is offline
Thanks guys!
Give the pads a bit more wear, they will improve.
Old 04-28-2016, 08:58 AM   #4
Azhule   Azhule is offline
Have you bled the brakes and swapped out to a 'known DOT brake fluid'?
I had some similar braking when we first got the Mrs. 'Bashan WILL', it took a few 'brake bleeding' sessions with new DOT4 fluid to 'stiffen up' the front brake, I also took the front caliper apart, clean/lubed/reassembled it to make sure it wasn't binding/stuck anywhere.
Old 04-28-2016, 12:22 PM   #5
Thanks HB! I will look into those. Luckily the Hawk already comes with a braided brake line
I will grab some more pads as well.
Old 04-28-2016, 12:23 PM   #6
Ive gone about 1000km on the bike so far, they definitely improved from when it arrived, it just doesnt instill confidence. haha
Old 04-28-2016, 12:25 PM   #7
I havent yet, I will try that today and see if it helps. It feels like it gets firm, and I cant pull it all the way to the handle bar. It just seems like there isn't a lot of "grab" if that makes sense.
Thanks!
Old 04-28-2016, 01:21 PM   #8
kohburn   kohburn is offline
kohburn's Avatar
wonder if your pads are glazed and not bedded in properly.
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 04-28-2016, 03:43 PM   #9
Can you sand them with sandpaper to restore them?
