04-11-2016, 05:36 PM | #32 |
Bearngs
Wonder if the TT uses the same bearings........
04-11-2016, 09:51 PM | #34 | |
http://www.chinariders.net/showthread.php?t=5243
04-12-2016, 12:54 AM | #35 |
I found NACHI brand Japanese bearings on Amazon, in the sizes you listed. They were about $7 each, as opposed to $1 - $3 for the other brands.
What is the size for the front wheel? I'll just make a go of it, and buy all 5 right now. |
04-12-2016, 12:59 AM | #36 | |
04-12-2016, 01:04 AM | #37 |
Post Edited to Correct Errors
CSC, Cyclone RX3 motorcycles sold in the United States contain the following bearings. Rear Hub Bearing Sizes Rear Hub Bearing, Sprocket Side: Two 6202 2RS Bearings Rear Hub Bearing, Brake Rotor Side: Two 6302 2RS Bearings Sprocket Carrier Bearing: 6004 2RS Forum members living in foreign countries might have an earlier version of the rear hub. It contains the following bearings. Rear Hub Bearing Sizes Rear Hub Bearing, Sprocket Side: 6202 2RS Rear Hub Bearing, Brake Rotor Side: 6302 2RS Sprocket Carrier Bearing: 6004 2RS
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 05-30-2016 at 02:21 AM. |
04-12-2016, 01:14 AM | #38 |
5 bearings totaled $22! For piece of mind, sounds good to me!
If I recall correctly, bearings were the only issue with some guy riding through Europe, right? |
04-12-2016, 02:35 AM | #39 | |
I think the Silk Road Rider only had problems with his rear wheel, and I wouldn't be surprised if it was only the 6202 bearing causing the problem. The 6302 bearings are large and robust. The 6004 bearing is serving light duty in the sprocket carrier. As long as these bearings are packed with sufficient grease, I don't think they will cause any problems. However, I received a replacement rear hub from CSC which only had two bearings. I suspect the Silk Road Rider had the same hub, and the weak spot is the single, 6202 bearing in the rear hub. RX3 bikes sold in North America have an upgraded rear hub which contains four bearings, instead of two.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 05-30-2016 at 02:25 AM. |
04-12-2016, 10:05 AM | #40 |
In post 37 you posted the bearing # as 6203. Is one a typo?
Can the bearings be re-greased in place (without removing them from the wheel)?
04-12-2016, 10:36 AM | #41 |
I made a typographical error in post #39, and I have corrected it. Thanks for letting me know.
Except for the 6004 bearing, all the other bearing numbers end in 02, which indicates an inside diameter of 15 millimeters, the diameter of the axle. The 6004 bearing of the sprocket carrier has an inside diameter of 20 millimeters, since it contains a bushing which has that outside diameter.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 04-12-2016 at 11:24 AM. |
04-12-2016, 10:45 AM | #42 |
Give it a try; you might be able to do it. You have nothing to lose by trying.
04-12-2016, 11:07 AM | #43 |
Here is a photograph of the SKF 6202 2RS bearing I installed in the sprocket side of the rear hub. Since I have an earlier version of the rear hub, I only installed one of these bearings. The bearings in the brake rotor side of the hub are 6302 2RS bearing. I used the orange pick to pry open the rubber seals from the inside diameter of the bearing. I packed the bearings with Lucas Red "N" Tacky #2 grease. The photo also shows my 15 mm split collet, and the large driver I used to drive the old bearings from the hub.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 05-30-2016 at 02:27 AM. |
04-12-2016, 11:11 AM | #44 |
Here is a photograph of the worn original bearings I removed from the rear hub. The 6302 bearing on the left was missing one of the rubber seals. This bearing was locked and dry.
The 6202 bearing on the right was completely shattered. I needed to cut the outer race with my dremel tool in order to remove it from the hub.
04-12-2016, 11:39 AM | #45 | |
