Old 01-28-2016, 10:22 PM   #1
CSaddict   CSaddict is offline
CSaddict's Avatar
AJP bikes. Zong powered
http://motoajp.com/ajp-enduros/pr5r/
Same mill as the RX3 that I can tell. More hp though. Interesting.
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 01-29-2016, 12:47 AM   #2
pete   pete is offline
pete's Avatar
Google the AJP PR7.... thats a real ADV bike....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-29-2016, 01:42 AM   #3
Yes, the AJP PR5 does employ the Zongshen NC250 (ZS177MM) engine. The Gas Gas EC Cami 250 also uses this Zongshen engine.
Old 01-29-2016, 01:53 AM   #4
pete's Avatar
Gas Gas have moved away from the Yamaha WR250f motors..
the things that happen when the wolfes are grawling at the door..
hope it works out for them... wouldn't like to see GAS GAS go belly up...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 01-29-2016, 07:30 AM   #5
Huck369   Huck369 is offline
Huck369's Avatar
I'd love to have a PR4........
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 01-29-2016, 11:44 AM   #6
The AJP bikes are nice.
Old 01-30-2016, 11:17 AM   #7
Krasi_BG   Krasi_BG is offline
... and expensive!
Old 01-30-2016, 12:12 PM   #8
keithmaine   keithmaine is offline
keithmaine's Avatar
AJP seat height 36"
2016 AJP PR7 Adventure Specs
Engine: 600cc liquid-cooled DOHC Single
Bore x Stroke: 100mm x 76.4mm
Compression Ratio: 12.4:1
Lubrication: Wet sump
Fueling: EFI with 45mm throttle body
Starter: Electric
Clutch: Oil bathed multidisc
Transmission: Six-speed
Frame: Composite aluminum steel
Front Suspension: 48mm USD telescopic fork, 11.8 inches travel, fully adjustable
Rear Suspension: AJP progressive linkage, Sachs piggyback shock, 11 inches travel, fully adjustable
Front Brake: 300mm disc, two-piston caliper
Rear Brake: 240mm disc, single-piston caliper
Front Tire: 90/90-21
Rear Tire: 140/80-18
Seat Height: 36.2 inches
Wheelbase: 60.6 inches
Ground Clearance: 12.6 inches
Fuel Capacity: 4.5 gallon
Weight: 364 pounds
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
