How To Changing Gear Sensor ( Stuck ) NC250/ZS177
Solving methode for, stuck screw, gear sensor replacement/changing.
Materials : 1. Toilet paper (most important mateial no:1 ) ![]() 2. Screwdiver (flat) 3. Old metal/wood handle knife 4. Gas / fire cooker 5. Maull / mallet ![]() Gear sensor of nc250/zs177 plastic/abs or idk. , simple cuted with hot metal prensibe ^^ ![]() 1 . Old knife on cooker stovve on gas fire, heat/roast bit red color is ok. (need 2-3 time) ![]() 2. Surgey with laser blade ^^ (use a towel, work safety every time no:1 ) ![]() 3. Cut it ok, remove need a FLAT screwdiver (gear sensor has O-Ring ![]() ![]() ![]() 4. Most important material life saver, toilet paper on action ^^ (happy sealing hole's ^^ , hygiene rules.. ![]() Mallet helped screw side impact for opened easy(stuck problem of screw.) ![]() 5. Old/original has 6. pin (1 neutral) 5. gear, new is ours RX3 sensor. mounted. ![]() ![]() |
Thanks for sharing the great photos.
![]() Why did you change the gear indicator? Did you switch from a 5-speed to a 6-speed transmission when you worked on your engine?
#3 | |
Moto has now 6.gear and ours RX3 sensor have 7 pin 7 contact surface in. 1 neutral 6 gear, 6+1 indictor on my speed screen fabricated has 6. gear indicator but sensor 5, now correct 6.th. ![]() Last edited by Co2; 11-27-2015 at 08:32 PM. |
Yes, I remember your engine rebuild project.
Worked sensor 6th. indicator active now, idk maybe all gear sensor of rx3/nc250's same.
Colours Dominant color / Little line color Neutral : Light Blue / Red 1. Gear : Pink (1 color) 2. Gear : Dark Blue / Red 3. Gear : Green / Black 4. Gear : Yellow / Red 5 .Gear : Yellow (1 color) 6. Gear : White / Blue Speedometer/tachometer different, only for RX3 spare gear sensor colors and gears. Happy end for gear sensor. ![]() |
The wiring colors for your dirt bike are very similar, but not exactly the same as those specified by the Colombian Owner's Manual for the AKT Adventour 250.
![]() http://www.chinariders.net/showpost....3&postcount=20 ![]()
