Old 10-23-2015, 03:52 PM   #31
Originally Posted by Juanro View Post
So, is there a replacement or compatible part number for the front brake pad?
I have not found an exact replacement for the front brake pad. However, I was told CSC is working with a company to produce an aftermarket, front brake pad for the RX3.
Old 10-24-2015, 12:01 AM   #32
3banger   3banger is offline
3banger's Avatar
I've noticed that after 3000 miles hard stopping, I like fast stops almost as quick acceleration, that my brakes have much better initial bite then when new. Maybe rotors and pads just have a really beding in time? I would still give a different pad material a try.
Old 10-24-2015, 06:34 PM   #33
Riceburner   Riceburner is offline
Riceburner's Avatar
Location: Tigbauan, Iloilo City, Panay Island, Philippines
I have just over 3000 Km (about 1,900 miles) and my brakes don't install confidence. I really don't like the feel and stopping distance's. I have tried to work them hard in non emergency situations but I'm just not happy.
My YBR125G has a disk up front and drum rear, granted it's a lighter bike but that things stops "now". Much better in proportion to weight. I took it for a ride a few days ago and "wow", I had to pay attention since I don't ride it as much but I loved the stopping effect.
I have the EBC Double-H, Sintered Rear Brake Pads (SKU#171657, from http://www.motorcycle-superstore.com/) that SpudRider had mentioned, in the mail to me now, along with a45 rear sprocket; I'll report my findings after install.
Riceburner
Robin / Face Hunter I
Medical Mission Matters
www.medicalmissionmatters.org
Old 10-25-2015, 09:52 PM   #34
Juanro   Juanro is offline
Juanro's Avatar
Just to let you know that I've instaled Honda XR250 "Tornado" front brake pad and they fitted just fine; I had to remove the little spring metal sheet inside the caliper, as the Honda's pad miss one of the tabs on the top part, and that piece touched the disk. Suppossedly that spring is to avoid pad rattle, but with it beign out I didn't noticed any strange noise.
Braking power and sensitivity is much improved, but a Little pumping action at the end of each brake is still there.
Old 10-25-2015, 11:09 PM   #35
Jay In Milpitas's Avatar
That is very helpful, Juanro! Did you use Honda parts or are they from another company like EBC? Do you know the part number?
Old 10-26-2015, 01:05 AM   #36
As I speculated in post #4 of this thread, EBC FA185 fits the Honda XR250 Tornado, 01-08 model years.
http://www.wemoto.com/bikes/honda/xr...tered_hh_type/
Vesrah VD-161 is the same brake pad.
Another equivalent brake pad is SBS 694.
Ferode FDB892 is also the same brake pad.
Old 10-26-2015, 01:11 AM   #37
This is the same front brake pad which fits my Honda XR650L, Honda CRF250X, and Kawasaki KDX220 motorcycles.
EBC FA185X: Red - Off Road
EBC FA185R: Sintered Off Road Utility
This is one of the most popular brake pads in the world, which fits dozens of Honda, Kawasaki, Suzuki, Yamaha, Beta, and Gas Gas motorcycles.
Old 10-26-2015, 08:36 AM   #38
Juanro's Avatar
Spud, yes. Which solves two issues: availability (plenty) and quality range (wide)
Now I wish I know which bike's brake DISC I could fit...
Old 10-26-2015, 08:42 AM   #39
Read post #19 in this thread. Do you know an inexpensive machinist? Many front brake rotors for KTM motorcycles will fit, but you need to drill the holes to accept the larger, Zongshen bolts.
Old 10-27-2015, 05:56 PM   #40
Juanro's Avatar
Spud, the mere mention of the word "ktm" will rise the Price of whatever you're looking for to sky levels around here... that's why I'm looking for a wider list of options to check out. Or, if you happen to know (or where can I find) the relevant size of the disc? Diameter I guess I could be safe with 260mm (given in the specs) but location and size of the mounting holes...?
Old 10-27-2015, 09:44 PM   #41
Here are several links with information regarding the KTM, front brake rotors.
http://www.ebay.com/itm/260mm-Front-...-/151550658023
The following link contains the KTM rotor measurements. Of course, you can also measure the front brake rotor of your Zongshen motorcycle.
http://www.amazon.com/Front-Rear-Bra.../dp/B00GMQJWWI
Outside Diameter: 260 mm
Inside Diameter: 127 mm
Number of Holes: Six
Bolt Hole Diameter: 143 mm
Old 10-28-2015, 06:19 PM   #42
Juanro's Avatar
Jay sorry I missed your post. Reading from the phone is not easy. No, I didn't use a genuine Honda part, I used one from a Brazilian manufacturer, FrasLe
Old 10-28-2015, 06:22 PM   #43
Juanro's Avatar
Spud thanks for the info, that's very usefully. I'll try to find a compatible part with the help of a vendor here.
Old 10-28-2015, 06:50 PM   #44
peperino   peperino is offline
I (just as Juanro) am suffering the same issue with the front brake. I proceeded to change the pads, here are some pics
Old 10-28-2015, 06:51 PM   #45
More pics
