Old 07-27-2015, 11:46 PM   #46
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
How do you like that bender Weld? I see one in the store and was unsure
about it. I looked at one the day I bought my mini air compressor.
Also picked up a cheap 1/2" drive impact wrench and man that thing is STOUT to be so cheap!
I am kinda a harbor freight junky! lol
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
Old 07-28-2015, 10:52 AM   #47
Me too! They have a 7" polisher on sale for $29.99 that I might grab tomorrow.
I've only used the bender a couple of times so far, but it worked well for me. I once found a video of a similar bender in use, and that sold me on it. Plus, they're stupid money where I live, so crossing the border for HF made sense.
I even bought the extra mandrels for it, so I can bend square tube.
Old 07-28-2015, 04:04 PM   #48
katoranger's Avatar
Originally Posted by Louis Angel View Post
WOW! Thanks for the offer man!
For now, for the moment, let me see what I can build, but
may hit you up in a day or two on those. :-D
Just let me know. I am not going to use them. I have a rolling chassis in my shed.
Old 07-31-2015, 09:35 PM   #49
I have been focusing my attention on the kitchen remodel, so not spen much time working on the scoot. But I am getting there (see next post)
the green & white dining room in the background is what I finished up last month, the wood cabinets used to be white and I refinished them, and the red paint that you can (barely) see is the new paint. Had to peel 3 layers of old a$$ wallpaper off to get to the 'rock just to paint! lol
Down to touch up spackling spots and this final wall.
Old 07-31-2015, 09:40 PM   #50
So here is where the scoot is at as of 07/31/2015.
I added captions to the pics so they are for the most part self explanatory.
Only REALLLLY bad snag I am running into is the 3-bolt pattern on the brake disc vs. the new wheel.
Factory brake disc is 3 on 2.5". New 13" wheel is 3 on 2.75"
So just get a new rotor, no biggy right? Noooooooo!!!!!!
The factory brake rotor is 6-1/4" OD. ALL brake rotors I can find online ( from over a 3 hour search) that do have the 2.75" 3-bolt pattern all are much larger OD. :-/ Dang.
anywhoo, pics:
Old 07-31-2015, 09:44 PM   #51
Adjuster's Avatar
You have two very nice projects going on.
Old 08-01-2015, 12:43 PM   #52
It looks like there was a "see-through" between the kitchen and the dining room. Did you panel over it recently? I'm guessing so, since 7/15 is painted on it.
How do you set the engine back? Does that mess with shock geometry?
Are you going to drill the rotors to suit?
Old 08-01-2015, 01:14 PM   #53
** Yep, the kitchen had that "80's styling" going on! LOL Had the white wagon wheel spindles in where that hole was. Was in perfect condition, but just very dated! So I tore all that out.
** The engine is set back by way of fabricating an entire new engine to frame mount. Now, if you own a Honda Ruckus, you can just buy this
part already made. If you want to spend $395 + S&H for it that is.
So I am building my own. As to the shock, the factory shock will have to be changed I am certain. No clue yet how much longer it will have to be.
May even have to move the upper shock mount back a bit to keep tings lined up right.
** Unsure about the rotors. Kind of leaning that way, but need to make sure if I drill the rotors out a bit that there will not be clearance issues with the brake caliper where the bolt heads pass through. That is still yet to be determined. What I do know is, for the moment, I will be running the factory 10" wheel in the front until I can get back to that issue latter on. Unless a Eureka moment happens.
Old 08-01-2015, 01:19 PM   #54
It looks like the innermost drilled holes in the rotor don't have scuff marks, indicating that the caliper doesn't extend that far. If that's the case, perhaps you'll have enough room to elongate the holes. You might need to clearance the body of the caliper a tad.
Can you get another rotor just like the one you have? That gives you a spare to play with.
Old 08-01-2015, 06:48 PM   #55
jct842   jct842 is offline
Or....If you have the where with how to redrill the correct spacing in the three unused spokes on the disk. A good divider would work on the lay out.
If it were mine thats what I would do. Once you got the layout all it would be is center punch and drill. A good drafting divider that locks is all you need.
Old 08-02-2015, 12:55 PM   #56
Excellent idea!
Old 08-09-2015, 01:16 PM   #57
IF ANYONE WAS CURIOUS ABOUT SIZE DIFFERENCE BETWEEN
A 2-STROKE MINARELLI ENGINE vs. A 4-STROKE " GY6 " LONG CASE ENGINE, HERE ARE A COUPLE OF COMPARISON PHOTOS
FOR FUTURE REFERNCE.
NOTE, THE MINARELLI 2-STROKE IS ALMOST THE SAME SIZE AS
A 50CC 4-STROKE QMB139 ENGINE.
Old 08-10-2015, 10:46 PM   #58
The mounting points don't look much different at all.
Old 08-12-2015, 09:07 PM   #59
That is what I thought, till the engine came in and I went to install the engine.
Very different in how they line up. :-/
Old 08-12-2015, 09:17 PM   #60
Ahhhhh crap!!!!
Dad blamit! Axle shaft is wayyyyyyyyyyyy too long!
Now I got to find a shorter axle. Grrrrrrrrrrrrrrrrrrrrrrrrrrrr.
