Old 05-13-2015, 10:28 PM   #1
FreyStarr   FreyStarr is offline
Head Scratching XR200R Lifan 163FML Valve Adjustment Gap Specs and running rich
Hi there.
I'm fairly new to this forum, lurked a bit looking for info, searched and couldn't find the info I wanted. This forum is broken up in a strange way, by type of bike instead of engine manufacturer... Wasn't sure where to post.
I have a Lifan motor in an XR200R frame that is having some issues, I thought one of the first things to do is to be sure the valves are in spec.
It has 163 FML printed in the side on the lower case.
It looks exactly like this
With the side port on the top, and the center black with the chrome side covers.
Is this the OHV or OHC engine?
Can anyone tell me the valve gap for intake and exhaust valves? I have the motion pro tappet tools so I think I can knock this out well...
A little about my problem, smoke coming out of the muffler and it won't run with the choke on, since choke makes the mixture richer it makes me think it's running really rich.
It has a Keihin PD97A which I think is the stock XR200 carb. I was thinking of getting the valves adjusted and changing the oil and then messing with the carburetor settings.
Old 05-13-2015, 11:35 PM   #2
humanbeing's Avatar
According to SAME bore/stroke Honda shop manual (url in ur PM) in/ex 0.1mm (ie .004")
Old 05-13-2015, 11:49 PM   #3
Originally Posted by humanbeing View Post
According to SAME bore/stroke Honda manual (url in ur PM) in/ex 0.1mm (ie .004")
Thanks for the PM!
I'll set it there, that seems reasonable.
It's odd that these engines don't have a manual. I feel like I'm back in the 80s before the internet trying to figure out how to work on my bike by word of mouth.
Old 05-14-2015, 12:27 AM   #4
humanbeing's Avatar
Originally Posted by FreyStarr View Post
...Keihin PD97A which I think is the stock XR200 carb...
Sometimes u need this http://www.ebay.com/itm/231284848909 in repair. OLD floats don't resistant to modern gasohol.
Old 05-18-2015, 04:27 AM   #5
so I cleaned the carb again, put in a rebuild kit and figured out which direction was choke
I play with the idle speed because I realized I was running it with choke on and starting with choke off.
I got it going pretty well but it's hard to tell because I don't have a tachometer
I have 15/50 gearing which I thought would be good for riding around town but it feels like it's very stressed at 5th gear at normal speeds. Maybe it's just a new bike with new sounds so I just have to get used to it.
Does anyone else have one of these motors in a street legal bike? or know of a bike that is made that comes with one?
Thanks
Old 05-18-2015, 08:01 AM   #6
wilserchinarider   wilserchinarider is offline
17/46 is pretty good gearing for street and light off road. 15/50 would be too low for me, The motor is likely screaming at 45-50 mph.
Old 05-18-2015, 09:37 AM   #7
humanbeing's Avatar
...I don't have a tachometer
...or know of a bike that is made that comes with one?
Thanks
Universal 2-in-1 (volt/ rpm) http://item.taobao.com/item.htm?id=15274249845 is a very useful tool when repairing scooter/ dirt bike / 'o shitty 4 wheeler ...
ALL 200 bike imported by American Lifan are using that OHC engine.
Old 05-18-2015, 12:18 PM   #8
ripcuda   ripcuda is offline
ripcuda's Avatar
Agreed. I have 15/46 currently on my Kinroad (200cc OHV)... and it's pretty wound-out at 55 on the road. I have a 17T front sprocket coming... hope to put it in the on-road, sweet spot.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 05-19-2015, 07:43 PM   #9
How on earth did you fit a 17 front? I had to chisel away the case a bit to fit a 15. There was a 12 on there when I got the bike(!) I'm running a 520 chain but I can't imagine it makes much difference.
Thanks for the input. I think I'll get a 41T to put on the rear. 15/41 is about the same ratio as 17/46
Old 05-19-2015, 07:44 PM   #10
Thank you.
I'll either get one of these or look for a Lifan gauge cluster, I would like a neutral light as this bike is for my sister and she's a new rider...
Old 05-19-2015, 07:45 PM   #11
A size 520, drive chain is much larger than size 428, drive chain.
Old 05-19-2015, 09:10 PM   #12
humanbeing's Avatar
...a Lifan gauge cluster...
Those are similar to appearance of http://www.cmsnl.com/honda-xl125s-19....html#resultsf .
Old 05-20-2015, 01:07 AM   #13
You're totally right
Every bike I've had has had a 520...
Here is a comparison
I found a 41T JT steel rear sprocket for 20 dollars so it's not a big deal but good to know.
Old 05-20-2015, 01:46 AM   #14
Wow; that is a great graphic! How did you get the sprockets to superimpose on each other?
Old 05-20-2015, 12:01 PM   #15
ripcuda's Avatar
I'll second that. That is a very useful pic for comparing sizes
Looks like he just put all three sprockets on the same shaft and took the pic.
Cheers!
'00 Yamaha TTR-90
