Old 03-11-2015, 04:54 PM   #1
wawoodwa   wawoodwa is offline
Voltage Regulator is Overcharging
Hello All!
We have been having fun with my son's 125cc ATV. However, we have run into a problem. The bike is overcharging. I tried replacing the voltage regulator, but I get the same results. Over 15v at idle and up to 17v mid-rpm. I have read where it could be the stator (which doesn't make sense to me, how does it overcharge as a failure mode?) or the battery. The regulators are the 4 pin model. I do not know how to test them independently.
Has anyone else run into a similar problem?
Old 03-12-2015, 09:39 AM   #2
lee47512   lee47512 is offline
Sounds like the regulator rectifier to me. I have never heard of a stator throwing to many volts that is what the rr is for.
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 03-12-2015, 10:12 AM   #3
I would agree. Is the replacement identical?
Old 03-13-2015, 01:20 AM   #4
Thanks all.
Identical in form. Not sure in function. It is a 4 pin, but I have no way of knowing with these things. They are super cheap.
I am considering finding a better one with wires and a pinout so I can wire it myself to make sure. Any suggestions on that front?
Old 03-13-2015, 01:46 AM   #5
humanbeing's Avatar
4-pin are NOT build equal
ALL DC
https://translate.google.com/transla...asp%3Fpid%3D37
AC light
https://translate.google.com/transla...asp%3Fpid%3D31
Old 04-08-2015, 12:38 PM   #6
Thanks all,
It is an AC/DC bike and regulator. Does anyone have a line on a good replacement? I could just have a lot of junk regulators.
Old 04-12-2015, 04:49 PM   #7
Tvnacman   Tvnacman is offline
Send a message via Skype™ to Tvnacman
Originally Posted by wawoodwa View Post
Thanks all,
can you post a few pics of the following and answer a few questions, then I can help.
lets see the original regulator, the stator plug. Tell me about the lighting is it ac or dc(can you put lights on without without the engine running?
http://www.nycscooterparts.com/
For tech help call John 2125980016
