Old 12-02-2014, 10:05 AM   #16
katoranger's Avatar
Check the keyswitch. It may not be working. My buggy will continue to run with the switch off, but does not charge the battery or run the lights unless the switch is on. You have to use the kill switch to shut it off.
Old 12-02-2014, 11:32 AM   #17
Originally Posted by bubby32 View Post
can't figure this out, I can cross the solenoid over and it will start and run, but no lights...will not start by starter button. Tao tao 125 manual shift. Tried the brakes while starting and all that
Welcome!
Is there any voltage to the primary side of the solenoid when you hit the starter button? Remove the small wires from the solenoid, connect a test light or meter to the wires, turn on the key, activate the brakes and hit the starter switch. Any sign of power there?
Old 02-19-2015, 06:25 PM   #18
Tao125f1   Tao125f1 is offline
On 125 manual nott starting and no lights.I would check fuse first.
On 125D mine would not climb any incline at all with me on it im (350LBS) it had 14 tooth front sprocket from factory so I put on 12 tooth sprocket on and its different night and day difference.
Old 03-06-2015, 03:12 PM   #19
ChinaATVMods   ChinaATVMods is offline
We did a 12 tooth front and 42 tooth rear sprocket. Sweet!
Old 08-31-2015, 01:47 PM   #20
madbare   madbare is offline
Where did you guys get your sprockets from and what style are they? I have 2 of these machines for my boys and they wont climb any hills at all, otherwise they run great and have been pretty much problem free. I would like to get a set of sprockets and start there. Is it possible to convert from the F-N-R transmission to a semi-auto?
Old 08-31-2015, 11:42 PM   #21
Stick with front sprocket changes; much easier and cheaper.
Remove the front sprocket and measure it, and we'll guide you from there.
The fastest and easiest way to convert to semi-auto is with a new motor.
Old 08-14-2020, 08:56 AM   #22
OneLeggedRider   OneLeggedRider is offline
OneLeggedRider's Avatar
Bump, good information here, just had to use Google as the search engine on here sucks!
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 08-25-2020, 04:05 PM   #23
Virtual_Rider   Virtual_Rider is offline
https://www.amazon.com/Wingsmoto-Spr...omotive&sr=1-1
This one worked like a charm on my T125. Can't guarantee it'll work on yours.
Old 09-01-2020, 11:45 AM   #24
If it were me I'd order the 420 sprocket just to be safe because alot of these come with a 420 chain. And even if it's a 428 chain the 420 sprocket will work. I bought a 10 and 11 tooth for my niece's 125.
Old 09-01-2020, 11:48 AM   #25
Just realized the post by madbare about sprockets was from 5yrs ago..
