Old 01-27-2015, 06:04 PM   #1
thommo1968   thommo1968 is offline
help identifying atv
Size:  71.1 KB hope you can see these as im not very goodwith computers
Old 01-27-2015, 06:08 PM   #2
other things that may help is engine says 167ml on it and vin says its 2005 from china (asia)
Old 01-27-2015, 08:42 PM   #3
Welcome!
Please show us a pic of the engine and the rear axle.
Old 01-28-2015, 12:03 AM   #4
TheGageinator   TheGageinator is offline
The neutral reverse indicator cover is on upside down.
Same part as my sunL though
Old 01-28-2015, 11:38 AM   #5
Old 01-28-2015, 11:57 AM   #6
one of my main problems im haveing is i cant get starter motor reduction gear to fit in the large gear is to big probs last owner didn't fit the right part
Old 01-28-2015, 02:12 PM   #7
Water cooled CG250 motor. Try searching eBay for CG250, and see what comes up.
Old 01-28-2015, 03:54 PM   #8
thank you and for my next question if thats ok i need a new reduction gear i think it is called as my starter didnt work so i bought a 9tooth starer motor but now my reduction gear wont fit and the bearings are missing on the gear Name:  gearr.jpg
Old 01-28-2015, 05:08 PM   #9
humanbeing's Avatar
Std CG 200 &+ uses 11T starter motor ...
http://mall.mxjidian.com/?de=goodsdetail,gid--100027
Old 01-29-2015, 06:29 AM   #10
I Need a new reduction gear all ready nought a new 9t starter motor
Old 01-29-2015, 07:35 AM   #11
Size:  49.3 KB only problem is i live in uk so cant find supplyer
Old 01-29-2015, 04:01 PM   #12
humanbeing's Avatar
Originally Posted by thommo1968 View Post
...only problem is i live in uk so cant find supplyer ...
There's supplier in UK, 18/62 is a standard CG125 parts.
Worst case can bought from China. http://item.taobao.com/item.htm?id=26437344913
Old 01-29-2015, 04:27 PM   #13
Hello thanks for your help what starter motor should I use on that set up 9t or 11t ?
Old 01-29-2015, 04:30 PM   #14
humanbeing's Avatar
Std CG125 is 9T http://mall.mxjidian.com/?de=goodsdetail,gid--100054
Old 01-29-2015, 08:00 PM   #15
Hi thanks that's what I bought so once my gear is here I can get quad running and then rebuild her to her formal glory I hope
