Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Free Classifieds > Parts & Accessories
Old 05-07-2013, 09:21 PM   #1
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
LOTS of LIFAN GY-5 parts AND motor parts
Everything you see here as well as a front wheel and a COMPLETE PARTS MOTOR (167FML pushrod version) I can pick parts off of as needed. I may have other parts that are not visible in the photo, PM for condition of parts or better photos I'm letting them go cheap to those in need. :wink:
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 05-08-2013, 01:26 AM   #2
Shipping from AK or MT? I'd be interested in the pushrod motor, but shipping might be prohibitively expensive for me.
Old 05-08-2013, 01:27 AM   #3
Do you have a good set of plastic side covers? Got a close-up pic of them?
Old 05-08-2013, 01:55 AM   #4
The upper white one has a little crack below the rear screw hole and was damaged by a forklift when it was being unloaded from the barge
Shipping is from alaska so the entire motor would probably not be possible, I think the valves and bore have been damaged from getting stored out side anyways
Old 05-08-2013, 02:03 AM   #5
I think that those would require more fab work than the GY150 covers I already bought. Is the tank plastic? Got a pic?
Old 05-08-2013, 02:18 AM   #6
I am planing on using the gas tank for the buggy project actually
Old 05-08-2013, 10:06 AM   #7
Ok, thanks anyway. I can't think of anything else I can use.
Old 05-09-2013, 06:05 PM   #8
edtardo   edtardo is offline
edtardo's Avatar
How much would you let the motor go for?
NewStar DB 200
Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson
Old 05-09-2013, 10:16 PM   #9
The motor has a bad top end from sitting out side and shipping from alaska would be $100+
Old 05-26-2013, 07:47 AM   #10
NewEnglandTrails   NewEnglandTrails is offline
I'd be interested in the front headlight housing if its still around... I have a Roketa db 05 and the housing is cracked in two. I see it in your o.p. but barely. Any chance on a front and back photo..?
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
Old 05-26-2013, 09:05 AM   #11
bogieboy's Avatar
Is the harness i spy complete? If so how much shipped to 60473? Thanks!
Old 05-26-2013, 11:24 AM   #12
edtardo's Avatar
I think that is a polisport mmx headlight
NewStar DB 200
Old 05-26-2013, 01:19 PM   #13
Hi it isnt a stock headlight it is a polisport as edtardo said. I will mount up to the stock mount on a gy-5 through the two upper holes. I never made a bracket for securing it better because it really didnt end up needing one. It is wired in to a plug for the gy-5.
I will have to double check but i believe it is complete except for the engine plug has been converted to bullet connectors because I was using it on my 400cc motor conversion. It would be pretty easy to convert back to the stock plug.
my first wiring harness failed and it took over a year of searching to find one that would work because they changed the wiring harness between years and countrys that the bikes were shipped to ( still had to change the turn signal wires on the bike to match this one). if you would like I can take pictures of all the connectors and you can compare it to yours.
Old 05-26-2013, 01:22 PM   #14
bogieboy's Avatar
i wont have the bike in my hands till saturday...LOL,i am know it needs a new harness, as the PO hacked it all up...at least he admits it...LOL
ifplugs dont match up thats not thebiggest issue forme to dealwith...LOLilike bullet connectors...easier to crimp than the stupid molex plug style....although i have acess to those too....LOL
Old 06-08-2013, 01:49 PM   #15
nyvdub89   nyvdub89 is offline
nyvdub89's Avatar
Hello Wild_Alaskan I was wondering if you had the throttle grip assembly for sale? I also need the choke cable, headlight plastic, and front brake booster if you have it available. Thanks man!
