Old 09-14-2011, 11:42 PM   #1
ssrider   ssrider is offline
2011 x31 valve adjustment
I bought a 2011 gio x31 250. It is the overhead cam motor. Has anybody ever done a valve adjustment on this bike? What are the specs?
Thanks
Old 09-15-2011, 07:43 AM   #2
humanbeing's Avatar
the MD33E (223) ancestor
Data copied from http://www.ride-inc.net/file/32/data.pdf IN /EX 0.10mm http://sawmee.jugem.jp/?eid=187
Old 09-15-2011, 08:55 AM   #3
I wish I could read chinese for that write up
Old 09-15-2011, 10:13 AM   #4
You can certainly search for XR200R valve adjustment specs and procedure. That will do nicely.
Old 09-15-2011, 10:21 AM   #5
Won't the specs and procedure be different as it is a different motor?
Old 09-16-2011, 01:35 AM   #6
It's a virtual clone of the XR200R. In fact, it's even closer to a CRF230, because it has electric start.
Doesn't really matter, because the engine doesn't know what name is on the outside. It boils down to the same procedure: find TDC on the compression stroke, set the valves to spec and have a nice day. The valve clearance specs you find for an XR200R will be just fine.
Old 09-16-2011, 06:42 AM   #7
humanbeing's Avatar
:idea: Use translate.google.com /Google Chorme for "foriegn" pages
btw: That page is in Japanese. Distinguish Sinosphere in their "modern" writing isn't that hard if knows "how" :wink:
Old 09-17-2011, 09:24 PM   #8
Thanks for the help guys. I found an awesome writeup on the crf230 valve adjustment if anyone is interested
http://nonderivative.com/motorcycles...alveclearance/
Old 09-18-2011, 12:36 PM   #9
That's exactly the procedure for my '96 XR250R, except I don't have the fancy tool; I use small Vise Grips (very gently).
Old 09-18-2011, 02:54 PM   #10
Good to know because I didn't really want to drop 50 bucks on that tool for the amount I would use it.
Old 09-18-2011, 03:46 PM   #11
I had a quick look online for a cheap version of that tool, but haven't found one yet. Maybe Tusk makes one.
