Old 08-10-2011, 11:05 PM   #16
That engine sure looks like an OHC Honda clone. I don't have any personal experience with using CRF parts in a China motor, but it makes sense. Once you have the engine in your hands, you'll be able to measure the camshaft and the piston to determine what else is available to you.
Old 08-11-2011, 01:35 AM   #17
anthonyfa18   anthonyfa18 is offline
but what service manual do i use ??? to rebuild that motor
2008 gio beast 200cc
mod list
YTX14-BS battery mod,gy6 carb 250cc,custom intake,125cc cf dirtbike muffler,MPR filter/intake,performance cdi,ngk iridium xi dpr8eix-9,performance coil pack and wire, pro taper handle bar, Gio air shocks, yam swing arm bus
Old 08-11-2011, 10:12 AM   #18
I can't guide you specifically Anthony, because I've never rebuilt one of those engines. My best guidance would be to take an XR200 service manual out from the library and see if the engine is identical. If it is, you can use the specs and procedures from the manual.
Old 08-11-2011, 12:55 PM   #19
is there any one on the forum that has rebuild this motor ???
mod list
