03-11-2021, 05:37 AM | #1 |
Custom BoomCat 125 build
Hello, I’m new to the forum and decided to show my bike.
Bought 6 months ago from MotorbikeCustoms in Ca, great guys and fast shipping bike arrived in about 2 weeks with no damage at all very pleased with the packaging and shipping company. Bike started right up but run poorly. This bikes carburetor is way too small for the 125cc, I believe they do this to pass emissions. I have fix most issues with the bike and made some changes as you can see. I’m not a certified mechanic but have wrenched a lot in my life do you get my experience and at time inexperience :lmao Mods: Hiaors-CB054 Pz22 carburetor re-jetted with 98 main, 35 pilot, needle clip on 3rd groove on bottom, air screw 1 1/2 turns out. Stock air cleaner. Bike runs excellent, very strong pulling, no bogging, FYI this setting can still change as time goes by, I don’t ride the bike much so still trying to get the best performance, 16 tooth front sprocket with 37 tooth rear, digital rpm gauge dash mounted. This bike will cruise at 55mph and so far I’ve topped it off 65mph at 7000 rpm. I believe this engine red lines at 8000 rpm. FYI updated the carb settings to #90 main and #30 pilot, and this is working great. This bikes are very low geared so if you want top speed, do the sprockets. Re-gearing also with give you a much smoother throttle response. I removed the front fender because it vibrates a lot since it’s very thin, I’m going to cut and modify it, for now I just made a custom cable holder to keep the brake and speedo cable from rubbing on front tire, tank stickers are custom made, and rear shocks are from my Kymco Spade, fits perfect. 7/8 drag bars make the bike look cooler but not as comfortable. But totally worth it! Next, doing the rear fender chop. First pics are the stock bike last pics is after mods. Any questions hit me up. Last edited by Aecker; 07-17-2021 at 10:41 PM. |
03-16-2021, 11:05 AM | #2 |
Fender less bracket
Hello I removed the front fender due to noise from vibration, the fender is very thin and I’m going to cut/mod to make it stronger and smaller, meanwhile this is the bracket I made, the rod and steel plate are from Home Depot, I think the bracket is just mild steel stock and the rod is a hanger of sort. After cutting and drilling the mounting holes next is welding it together. After just paint. This is just a idea you can come up with your own. You need this to keep the cables from rubbing on the front tire.
Fork tube gaiters or boots 8x25mm eBay. Last edited by Aecker; 03-17-2021 at 04:30 PM. |
03-16-2021, 11:10 AM | #3 |
Nice job!
03-16-2021, 03:44 PM | #4 |
Thank you kind sir!
06-17-2022, 08:20 AM | #5 |
are the back shocks an improvement? where would I get these?
06-22-2022, 08:54 PM | #6 |
Rear shocks
Yes, the OEM shocks are terrible, mine caused vibration at high speed, this are from a Kymco Spade and fit great and improved the ride a lot. U can find decent shocks on Amazon, RFY air reservoir shocks are a good value at $80. I got a set for my Spade.
06-22-2022, 11:12 PM | #7 |
I'd buy one just so I could use the name Boomcat on a regular basis.....
07-03-2022, 07:34 PM | #8 |
New fairing on the Boom.
