08-25-2017, 10:42 PM | #1 |
Bashan enforcer kill switch and turn signals
Hello all. I just recieved and assembled my Bashan enforcer from apscusa. I am also new to this forum looking for others that have an enforcer to troubleshoot and trade notes with.
Two questions: 1) When you start the bike with the remote electric starter without having the key in the ignition, how do you kill the engine? There is not a kill switch that I could find on the handlebars. Sticking the key in the ignition and turning it on and off does not do the trick either. I was forced to turn the fuel cock off and hit the throttle. 2) When installing the front blinkers, has anyone actually gotten them to work? I've tried many combinations in the wiring hook ups and have had no luck getting them to work. Thanks and I look forward to hearing from yall! |
08-26-2017, 01:37 AM | #2 |
Start it with out the key in the ignition ?
theres something very wrong in the wireing.... ..
09-02-2019, 07:32 AM | #3 | |
Or under the seat or anywhere the black wire to battery positive n away you go. ALL these are easy to steal. My RX3 turns on with a remote AND THERE IS NO KEY NOW, harder to steal but still fairly easy if you spend a few minutes and have some wire |
08-26-2017, 11:22 AM | #5 | |
08-26-2017, 11:54 AM | #6 | |
I tried the remote starter once and it acted weird something like it would not start again or shut off. I do not remember anyhow I never used it again.
2016 Brozz |
08-26-2017, 11:58 AM | #7 |
Regarding the blinkers do the back ones work?
I had no issues with the blinkers
2016 Brozz |
08-26-2017, 03:20 PM | #8 | |
P.S. Has anyone seen an operators manual for the Enforcer? I'd like to see a PDF file of it...ARH |
08-26-2017, 03:34 PM | #9 |
I wonder if the kill switch is mandatory if it has a key switch?
2016 Brozz |
08-26-2017, 03:36 PM | #10 |
Every image I have seen of a Brozz where the controls were visible I have seen the exact same ignition kill switch and starter button that is found on the Hawk.
Also, kill switches are mandated by the Department of Transportation. It's not an optional thing. If your bike is being delivered without a functioning kill switch, then that is a flaw and it would fail safety inspection in any state that has them.
08-26-2017, 03:46 PM | #11 |
My kill switch operates the hazards lol. Sounds like we are all going n the same boat
08-26-2017, 04:06 PM | #12 | |
I bet there is a stipulation with the remote that allows for the exemption of the kill switch. The switch on the right is NOT a kill switch it is a switch that turns on the 4 blinkers ie hazard lights. I rewired mine to be a Kill switch so I can do a spark chop. If anyone needs the info I can dig up the post that I explained how to do it.
2016 Brozz |
08-26-2017, 03:46 PM | #13 |
On a completly different Chinese bike I seen that if you use the remote 'start' button then I believe it was the 'lock' button or something strange like that on the remote that turned it off. Try all the buttons on the remote. There may be a loophole in the law that the remote is also your kill switch. Sounds terribly unsafe I know but the law has many loopholes and the Chinese seem to exploit them.
08-26-2017, 04:08 PM | #14 | |
You are right about the lock of the remote. I tried it once and found it a complete waste why would I want to start my bike from a distance?
2016 Brozz |
08-26-2017, 04:21 PM | #15 |
Remote Operation
Here is the instructions for the remote.
The translation is typical Chinese to English Note the bullet Anti-rob This is the way around the kill switch.
2016 Brozz |
