Bashan enforcer kill switch and turn signals
Hello all. I just recieved and assembled my Bashan enforcer from apscusa. I am also new to this forum looking for others that have an enforcer to troubleshoot and trade notes with.
Two questions: 1) When you start the bike with the remote electric starter without having the key in the ignition, how do you kill the engine? There is not a kill switch that I could find on the handlebars. Sticking the key in the ignition and turning it on and off does not do the trick either. I was forced to turn the fuel cock off and hit the throttle. 2) When installing the front blinkers, has anyone actually gotten them to work? I've tried many combinations in the wiring hook ups and have had no luck getting them to work. Thanks and I look forward to hearing from yall! |
Start it with out the key in the ignition ?
theres something very wrong in the wireing.... .. |
I tried the remote starter once and it acted weird something like it would not start again or shut off. I do not remember anyhow I never used it again. |
Regarding the blinkers do the back ones work?
I had no issues with the blinkers |
P.S. Has anyone seen an operators manual for the Enforcer? I'd like to see a PDF file of it...ARH |
Every image I have seen of a Brozz where the controls were visible I have seen the exact same ignition kill switch and starter button that is found on the Hawk.
Also, kill switches are mandated by the Department of Transportation. It's not an optional thing. If your bike is being delivered without a functioning kill switch, then that is a flaw and it would fail safety inspection in any state that has them. |
On a completly different Chinese bike I seen that if you use the remote 'start' button then I believe it was the 'lock' button or something strange like that on the remote that turned it off. Try all the buttons on the remote. There may be a loophole in the law that the remote is also your kill switch. Sounds terribly unsafe I know but the law has many loopholes and the Chinese seem to exploit them.
My kill switch operates the hazards lol. Sounds like we are all going n the same boat
I bet there is a stipulation with the remote that allows for the exemption of the kill switch. The switch on the right is NOT a kill switch it is a switch that turns on the 4 blinkers ie hazard lights. I rewired mine to be a Kill switch so I can do a spark chop. If anyone needs the info I can dig up the post that I explained how to do it. |
You are right about the lock of the remote. I tried it once and found it a complete waste why would I want to start my bike from a distance? |
Remote Operation
1 Attachment(s)
Here is the instructions for the remote.
The translation is typical Chinese to English Note the bullet Anti-rob This is the way around the kill switch. |
Rewire Hazard Switch to Kill Switch
From the post I made on how to wire the switch
I rewired this today. Interesting the blue and orange flasher wires have a diode in line. The three wires you need to modify are the blue, orange and gray wires. I took the switch and harness off the bike so I could remove the wires from the molex plug. To remove the wires from the plug use a small screwdriver or dental pick to push the holder on the pin. I removed the harness cover at this point you will see where the blue wire is spliced and another wire is added the orange wire and the diodes are placed in line. I cut the the blue wire before the splice and then I spliced in a wire to match the length of the gray wire. I cut the gray wire to remove the connector. You now have the two wires you need to splice into the ignition switch harness. I removed the green and black wire with white stripe from the molex connector. I then used an exacto knife to remove about 3/8 inch of insulation right before the pin. I then soldered the blue and gray wires to the green and black/white stripe wires. I used shrink tubing to finish the wires up and put the wires back into the molex connector. I now have a kill switch. and no emergency flashers. |
There is no kill switch on the Shark either. Now on the remote start, if you hit the unlock button after its started it will kill the engine. I just used a cheap toggle switch and wired it up as a kill switch. As far as I know, none of the Brozz/Sharks came with them. |
