Old 05-18-2024, 12:15 AM   #1
Jakerider   Jakerider is offline
Doh! How screwed am I (tt250)
Hey everyone. I was doing an oil change on my 2019 tt250 and while unscrewing the drain plug part of the thread just fell out. It’s leaking a ton of oil now even with the plug in as far as I can turn it. I know how to weld and could try to seal it back up, but it would be a decent amount of work to get it to the shop I weld at. Anyone have any ideas?
This image is with the piece that fell out shoved back in place (it still leaks oil)
Old 05-18-2024, 01:19 AM   #2
If you can get it clean enough - aka oil free - your best bet would either be to weld it on or epoxy it back in place. Then just chase the threads out.
You could use a die to cut an aluminum thread insert and then weld the hole shut and do your oil changes from the filter screen side as a secondary option. A lot of the newer CG and CB engines don't even come with a lower drain plug.
Otherwise, you need a new case half.
Old 05-18-2024, 07:28 AM   #3
severely   severely is offline
Or maybe just find the next larger size drain plug and tap to that thread pitch. Good luck.
Old 05-18-2024, 08:43 AM   #4
You can't tap into metal that isn't there. Look closely at the pictures and you will see that a chunk of the case containing a not insignificant percentage of threads that the sump plug goes into.
Old 05-18-2024, 09:03 AM   #5
Do©Hawk   Do©Hawk is offline
What about something like PIG high temp epoxy putty? I've heard some good stories about it from people far more mechanical than I.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* LED headlight + front turn signals
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 05-18-2024, 09:23 AM   #6
Aussie_in_MO   Aussie_in_MO is offline
You may get away with epoxy putty or JB Weld.
Surfaces will need to be immaculately clean and you'll need to be very very careful when torquing the drain plug back in after it's set.
I'd almost be leaning towards epoxying the missing piece back in, epoxying the drain bolt in place, and doing your oil changes through the filter screen side plug.
Welding cast aluminum can be a major pain due to unknown alloy, outgassing and oil contamination.
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 05-18-2024, 10:27 AM   #7
Here is a completely different idea.
A replacement engine costs under $500. You may even choose to upgrade to a 249cc engine, which might cost a bit more. But the amount of work involved and chances of failure really beg the question, "Is it worth the effort?"
The only way to fix this problem with certainly is to break the crankcase in half and replace the broken side. But once you've done that, you may need to replace the seals on the ends of the shafts in addition to the gaskets. What would the parts total be? Can you find them?
And it is a whole lot of labor. Do you have bench space in a shop to do this work? Once it is all back together, it is a used Chinese engine that has been broken down and rebuilt. Sure, it can be done, but swapping in a fresh engine is much less work.
Just a thought. The quick fix (JB Weld or welding) could work. Just thinking that if it fails, what next?
Old 05-18-2024, 11:56 AM   #8
You effed up.
I would suggest to get another plug that has a bigger thread diameter, but it looks like the case is cracked.
If you're lucky, JB weld can fix that somewhat, as the crank case and oil aren't pressurized, but no guarantees. It needs welding.
Alternatively, I've never tried, but, drain the oil overnight; wipe all excess, get some high tin solder, and a propane torch, and hope for the best that solder will work. Solder won't melt with the temperatures on that part of the engine.
Old 05-18-2024, 12:04 PM   #9
Looks like it may have been smacked at one time. You do any real off-roading?
I'd clean it up good, put a haze of anti-seize on the exposed threads and back of the bolt head and then fill a patch of JB Weld over it. Let it set for a couple days and fill it with oil and keep your fingers crossed.
We just had a guy on the RE forum fill a dime size hole in his Himalayan case and it worked great.
Old 05-18-2024, 12:11 PM   #10
OldRedTabbys   OldRedTabbys is offline
Welding pourous, cast aluminum that has been sitting in oil is not going to go well. I would clean it up best you can and JB weld the plug right in. You can always just lean the bike over to drain the oil for future changes.
Old 05-18-2024, 01:32 PM   #11
I’m going to try this in the next few days. I actually never got to ride the bike lol. I bought it from a mutual friend who told me he only did casual fire roads. I highly doubt he was lying. We live in a national forest so there are no dirt trails that you can legally ride on in the nearby area. Also when I was taking the drain plug off, it was insanely tight. I barely got it off. There was a good amount of metal flakes in the oil, but I read online that it’s fairly normal for the first few oil changes on the tt250. However there was absolutely no metal in the filter. Kind of odd.
Old 05-18-2024, 03:21 PM   #12
WAY overtightened on the last oil change. That did it in.
Old 05-18-2024, 09:53 PM   #13
The "filter" is only there to protect the oil pump from large shavings and chunks of metal. Think of it more like a kitchen strainer than an oil filter. The actual oil filtration doesn't use a filter at all, but is a centrifuge driven off of he crank sitting right next to the clutch. It spins the oil to separate the heavier metal particles out. All that is left after that is the very fine stuff that is so small it doesn't really harm anything.
Also, keep in mind that the CG engine design in particular is intended to be a bit "loose" on the tolerances so it can survive third world abuse (dusty conditions, infrequent oil changes using sub-par oil, etc). Even an "abusive" owner by Western Standards is going to give it far more care than it was designed to tolerate.
