Old 05-05-2024, 08:19 PM   #1
Rezin   Rezin is offline
Titan 250 - Where to Buy Front Left Engine Case Gasket
Had to remove the case on the front left part of the motor due replacing the starter and the gasket tore. Anyone know the part number or know where I can buy one?
Old 05-05-2024, 08:59 PM   #2
Should I just buy some gasket maker since its just the clutch cover?
Old 05-05-2024, 10:08 PM   #3
Thumper   Thumper is online now
I assume you are talking about the stator cover gasket on a 169FMM engine?
I think the OHC and pushrod versions use the same gasket, but not sure. What is the enigine model number (behind the gearshift on the block)?
Google
stator cover gasket 169FMM
A few options show up.
Old 05-06-2024, 07:23 AM   #4
Yeah Stator Cover Gasket is correct. Need to figure out the model.
Old 05-06-2024, 08:05 AM   #5
buzz   buzz is offline
silcone gasket maker,get a good brand.
