Old 05-01-2024, 05:25 PM   #1
Phane   Phane is offline
KPR 200 stalls and loses power when riding
Does anyone else have a problem with their bike stalling and losing power while riding? Do you know what causes this! Valves have been adjusted and plenty of fuel! Oil was changed at break in and again at 300 miles! Have only 534 mile as of date,
Old 05-01-2024, 05:56 PM   #2
herbie   herbie is offline
How did it run after the valve adjustment and how many miles ago did you adjust them? I can’t say that I’ve ever experienced that with this engine but if it was mine the first thing I would do is check compression. You should have between 170- 195 psi most likely. If you have low compression then revisit your valve adjustment.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
