Old 04-28-2024, 01:44 PM   #1
Notjoemechanic   Notjoemechanic is offline
Ebay crf230f upgrade cam and roller rockers for 165fml
I've been eyeing some chinese performance camshafts with roller rockers on Ebay for quite some time that are for a crf230f. For about 50 bucks it seems like it would be worth a shot for my zs165fml motor. I'm trying to gain a little more top end grunt for highway riding. It will hit 75mph with current setup and I usually keep it to 60 or 65. I'm fine with the top speed I would like a little more acceleration for passing power when going up hills and against wind gusts and such. Anyways I'm wondering if anyone has used these cam setups with stock valve springs or have any recommendations for springs and cam timing etc.
Old 04-28-2024, 02:36 PM   #2
alex_in_az   alex_in_az is offline
is the zs165fml OHC?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 04-28-2024, 04:02 PM   #3
Thats right. Its the 223cc ohc motor. From what I gather all the crf230 internals are compatible.
Old 05-21-2024, 08:55 AM   #4
I just ordered the ebay camshaft and silent roller rockers kit. I bought one with an "upgraded camshaft." It should be in by the end of this month. I plan on documenting the process here with pictures showing the difference between the new and old cams. I will probably do some port cleanup and possibly adjust my squish clearance if there is enough valve to piston clearance. I should gain some power and efficiency there. I'm going to steer clear of any changes to port geometry and just do a 60 grit finish on the intake side and blend any sharp edges I find including the combustion chamber. Oh and if anyone has any torque specs they would like to share or possibly point me to a reliable source that would be awesome! Hopefully this will help someone else decide if they want to try to bend a valve in their engine. I hope the stock springs hold out.
Old 05-25-2024, 08:43 PM   #5
Just got the cam and roller rockers in Friday. I went ahead and lightened the rockers a bit. They seem a bit chunky. Hopefully in the next week or two I will get a chance to remove and tear down the motor.
ID:	31481   Click image for larger version
ID:	31482   Click image for larger version
