04-18-2024, 10:21 AM | #1 |
Need help!!
Just recently got a bike on trade and the guy told me it was a 2016 Baja Motorsports x250. The vin says it’s a 2006 Zongshen 200cc. The motor has Baja badging and so does the seat. Can someone help identify what I have. Engine code is ZS169FML. Frame vin is LZSJCML0565167480
04-18-2024, 11:57 AM | #2 |
That's definitely a 200cc engine code.
Plugging the VIN into here (https://vpic.nhtsa.dot.gov/decoder/) results in: Manufacturer: CHONGQING ZONGSHEN AUTOMOBILE INDUSTRY CO., LTD. DBAs: Vehicle Type: MOTORCYCLE Model Year: 2006 Make: ZONGSHEN INDUSTRIAL GROUP CO., LTD. Model: UM DUAL SPORTMOTO 200 Body Class: Motorcycle - Dual Sport / Adventure / Supermoto / On/Off-road
---------- 2023 Templar X 2009 Triumph Bonneville 1976 Yamaha DT175 1974 Honda MT125 Last edited by Aussie_in_MO; 04-18-2024 at 01:03 PM. |
04-18-2024, 12:43 PM | #3 |
Thumbs up to see someone else using the VIN decoder, here is the URL that will open, just chop off the last section of the above URL.
04-18-2024, 01:03 PM | #4 | |
Good catch Texas Pete. Fixed my link
---------- 2023 Templar X 2009 Triumph Bonneville 1976 Yamaha DT175 1974 Honda MT125 |
04-18-2024, 05:49 PM | #5 |
But why is it badged out in Baja badges but the frame vin comes up as Zongshen? Did Zongshen build Baja?
04-18-2024, 06:17 PM | #6 |
Yes, very likely. Zongshen builds bikes for many brands. CSC bikes are Zongshen.
04-18-2024, 07:29 PM | #7 |
Pictures may help out a bit if you can post them.
Could be that someone swapped parts from one bike to another. Either way it's almost definitely not a 250cc in spite of what you were told.
04-19-2024, 11:19 AM | #8 |
Here are some pictures. But I’m gunna assume that it’s a 2006 Baja ssr200 that someone put a 21” on the front and 18” on the rear. |
04-19-2024, 11:21 AM | #9 |
https://share.icloud.com/photos/0fff...BgBLOG9cuD6P_Q
https://share.icloud.com/photos/0acg...9UpUuBK_Tq2G8A https://share.icloud.com/photos/02fz...g6SsSNA7C9buNw |
