Old 12-18-2023, 07:17 AM   #1
Ascot500   Ascot500 is offline
Horizontal Engine Codes
OK. I am looking for a horizontal clone clone engine for a project with these specs:
90-110cc
Kick start
Semi-auto 4 speed
N-1-2-3-4 pattern
As I peruse on-line the offerings, I see a lot of contradictions in listings, like in one place saying it's a 4-speed pit bike engine while in the specs it says R-1-2-3
Or seeing a clutch lever on the case when it says semi- auto
So how can I be sure an engine has what I want?
Do the numbers stamped below the sprocket have a decipher code?
Old 12-18-2023, 07:57 AM   #2
dirtbkr188   dirtbkr188 is offline
dirtbkr188's Avatar
Supposedly, only the engine displacement and bore size can be deciphered from the engine VIN...but.... The Chinese engine manufacturers take great liberties when branding their engines. They aren't always what they say they are.
Old 12-18-2023, 08:00 AM   #3
Thanks - this is great information
Old 12-18-2023, 08:15 AM   #4
dirtbkr188's Avatar
A case in point...
I have an engine here with the engine VIN - TZH152FMH - which, according to the chart above, has a 52mm bore and 110cc displacement. I know the stroke is 49.5mm, and when the formula is applied, here is the result.
5.2 x 5.2 x 4.95 x .7854 = 105.12cc displacement
The thing is, the cylinder has a 90cc casting on it, and when I removed the head, I found that the bore size was only 47mm, not 52mm, as the engine VIN states. Applying the formula to that number -
4.7 x 4.7 x 4.95 x .7854 = 85.87cc displacement
As I said above, they are not always what they say they are.
Old 12-18-2023, 09:10 AM   #5
Mudflap   Mudflap is offline
Originally Posted by dirtbkr188 View Post
A case in point...
The CG engine in my old quad was coded as 71mm bore but I measured it as 63mm so I agree they are sometimes miscoded.
