Old 07-23-2022, 12:21 PM   #1
Jerrypcman   Jerrypcman is offline
Hawk 250 boggy carb issue
Have the aftermarket P30 carb, new bike runs good except when about mid throttle I’ll be riding along and back the throttle a bit to coast/slow down for a second then give it gas again and it Boggs/hesitates then catches back up.
Any idea would be helpful. Running 140/35 jets, clip on second notch up on needle.
Old 07-23-2022, 12:40 PM   #2
Thumper   Thumper is online now
You can read your spark plug. The difference between rich and lean should be detectable. This will give you a clue whether you need to rejet or change needle shim/setting.
There are dozens of resources with pics on the web. Here is one.
https://www.tuningmatters.com/how-to...retor-setting/
Old 07-23-2022, 05:18 PM   #3
XLsior   XLsior is offline
XLsior's Avatar
also check for any inlet manifold leaks between the carb and head.
Old 07-23-2022, 07:37 PM   #4
BrokeAss   BrokeAss is offline
BrokeAss's Avatar
That works for your main jet after a WOT run. Won't diagnose a mid throttle stumble.
Old 07-25-2022, 01:35 PM   #5
dr1445   dr1445 is offline
raise the needle by moving the clip down one notch.
carb issues
