Old 04-09-2022, 10:13 AM   #1
Hozer   Hozer is offline
Clutch Cable Adj!
I need to loose'n my clutch but the cable on the clutch handle is all the way in. When I start the bike the bike move just a taste! Now on the clutch lever on the other end on the bike I see no adj., but there is a lever with a spring on it. My question is can I take that spring off and move the lever up to I can adj. the clutch cable better? here is a pic!
here is the link to pic just in case: NOTE: you will need to click on pic to see full size!
http://ibb.co/NYhcY2P
Old 04-09-2022, 11:08 PM   #2
pete   pete is offline
pete's Avatar
is there a adjuster somewhere in the center of the cable..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-09-2022, 11:27 PM   #3
Coloradogoose   Coloradogoose is offline
I can't see where the housing for the cable stops in the picture. Is there a barrel adjuster there that you could run in a bit to loosen things up?
Does your clutch lever have adjustable reach? Like a set screw that keeps it from sitting all the way out? Usually when the reach is adjusted closer to the bar it pulls cable with it.
If nothing else works a picture of the lever might help us make guesses on how to mod things a bit.
Old 04-11-2022, 11:54 AM   #4
What I had to do is remove the side panel to get to the adjuster. What a pain in the ass lol. I got the clutch to work correctly now. Thanks all.
Side note:
Where can I buy another clutch cable that won't break the bank?
Thanks guys!
