Old 07-01-2021, 06:40 PM   #1
jatgm12   jatgm12 is offline
2014-18 brozz rear wheel help
Would anyone with a 2014 through 2018 brozz be able to take photographs of their rear wheel so I could see if that wheel will fit my motorcycle? I have a shark 250 And want to make sure it's the same. I'm trying to figure out how far the sprocket is from the center of the wheel, And how the bol ts attach to the sprocket from the wheel. Also what size bolt goes through the wheel And how the drum brake mounts. I'm not sure why it's so hard to just find a wheel. There are no specifications listed on the website selling a wheel for a brozz so I have no real way of measuring anything to check.
Old 07-01-2021, 07:04 PM   #2
Kinda just wanna try to eyeball it to see if it's similar enough to work. I can't imagine theirs that many variations.
Old 05-14-2024, 03:51 PM   #3
crkwbrozz   crkwbrozz is offline
unable to find a 42 or 43 tooth rear sprocket for my 2018 brozz with a rear drum break. does anyone know where to find one.
Old 05-14-2024, 05:01 PM   #4
jeffrey   jeffrey is offline
The rear sprocket you are looking for is a JTR 810 for a Suzuki GN125. Look for it on ebay.
