Old 03-02-2021, 01:52 PM   #1
RussellTA   RussellTA is offline
RussellTA's Avatar
X-Pect Fork Specs
Does anyone know what the forks on a Lifan X-Pect are a replica of? I am kinda thinking they are XR200 but they look a little different. They appear to be a 31mm tube but I can’t seem to cross reference that to a comparable bike that I can find specs on.
I am trying to find fluid level specs as I want to add a little fluid to slow down the mid-range damping but I don’t want to go over the max spec
Old 03-02-2021, 03:12 PM   #2
franque   franque is offline
Just add a little bit at a time, and keep records. It could be twinshock XR200, but forks aren't something that people tend to research as much, particularly what/whether they're copied. I would drain the forks to see how much fluid you've got in them, and then try adding oil in 10mL increments until you get where you want to be. You could also try thicker fork oil. If the oil starts blowing out of the seals, you know you've added too much.
Old 03-02-2021, 08:40 PM   #3
RussellTA's Avatar
Well I decided to just go with my old boomer knowledge.
I added 10cc of 5wt fork oil to the existing factory stuff in the fork. I would have done 7wt but I had 5 sitting around, and as it turns out 5 was perfect.
What a difference, still have the 1.5” sag that I wanted to keep and now the mid to bottom stroke is perfect, firms up exactly as I was hoping so no bottoming expected and I still have the soft suspension at the top end.
Happy X-Pecter
As you travel down the road of life, keep your eye upon the donut, not upon the hole
2020 Lifan X-Pect 200efi
2005 Harley Davidson Sportster XL1200R
