Old 09-06-2020, 09:38 AM   #1
Dbrown672   Dbrown672 is offline
Brozz 250 electric starter issue
Hello everyone. I have a 2018 Brozz 250, 650 miles on it. The battery died on it once from me not starting it. I ended up pop starting it. Ran it for a while to recharge battery.
Now even with the battery re charged, the electric start won’t turn the engine over. It really tries but just can’t get it to turn. I have to pop start every time I want to turn it on.
Anyone ever have a similar issue? Any help would be greatly appreciated!
Old 09-06-2020, 11:37 AM   #2
Magician16   Magician16 is offline
You need a new battery. If you let these little batteries go all the way down, they are usually toast.
Old 09-06-2020, 01:06 PM   #3
Thanks for the reply. the lights and all the electronics are working with what seems to be full power.
I hope that is the issues seems to be an easy fix
Old 09-06-2020, 01:52 PM   #4
cycleway4   cycleway4 is offline
Probably need a new battery....you have 12 volts now that its charged,..powers lights just fine,..but you dont have enough amps to turn the starter...
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 09-06-2020, 07:28 PM   #5
That makes sense. I’m going to try the battery. Any recommendations on where to find a good price on one? Also, is it just a normal 12V motorcycle battery?
Really appreciate the quick replies!
Old 09-06-2020, 10:45 PM   #6
NzBrakelathes's Avatar
why not jump start from a car - this will tell you if battery is Ok or not.....
Old 09-07-2020, 09:27 AM   #7
Get the number off your battery , and then search Ebay with that number, i recently got gel cell batteries which are very good for two of my Bikes off there for less than $35 each . , I'm sure the same Vendor has one that will fit your Brozz.,and they are much better than the stock one.
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
brozz 250, starter
