01-07-2019, 11:35 PM | #1 |
Hawk 250 Front rim
Looking for a front rim for the Hawk 250, would prefer the black rim. Also need 2 fork tubes.
01-08-2019, 05:10 PM | #2 |
New or used?
01-08-2019, 07:07 PM | #3 |
If we are talking just the actual outer rim, an 21 x 1.6 36 hole front wheel from any old Honda will work.
If you need the full wheel assembly, then you have to order through RPS or an RPS dealer that sells parts for them. The same goes for the forks. Links to parts via 360powersports. Right fork. https://www.360powersports.com/ricky....100031.01.htm Left fork. https://www.360powersports.com/ricky....100031.02.htm Front wheel. https://www.360powersports.com/ricky....100029.02.htm Total cost: $305 plus any shipping. Also, be prepared to wait a couple months. Myself and two others who bought front wheels ended up waiting that long for ours. When you put the order in, if there is a place for notes/requests type in that you want a black rim. As a side note, if you are going to order a new front wheel assembly, I would happily buy that front wheel hub off of you, minus the spokes and outer rim.
01-08-2019, 09:42 PM | #4 |
Hawk Front Forks
I've got a nice new set of forkes I'd part with. P.M. Me if your interested.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
01-09-2019, 01:42 PM | #5 |
01-09-2019, 01:43 PM | #6 | |
01-09-2019, 02:00 PM | #7 |
01-09-2019, 02:13 PM | #8 |
I had to wait 2 months for a full wheel assembly. You could always ask how long just the rim would take. Don't forget to get spokes to replace any bent ones.
01-12-2019, 03:52 AM | #9 |
find someone with a press...
those fork stantions can be straightened .. ..
01-14-2019, 08:18 PM | #11 |
and people wondered why i wanted to switch to excel rims or something better than stock because this steel garbage bends to easy.
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
01-15-2019, 08:40 AM | #12 |
I agree. I would replace them with a better quality aluminum rim before buying the OEM ones. I've been lucky so far. Also get in the habit of checking and maintaining the spokes will help prevent spokes from breaking.
01-15-2019, 09:29 AM | #13 | |
While you will not hear a peep out of me disagreeing with the stock rims and spokes being fairly wimptastic, I also remind myself to look at the picture of both fork tubes being pretty well bent as well. Considering how hard that impact was, that wheel came out pretty well.
01-15-2019, 09:37 AM | #14 | |
Come on TejasJoe, What happened? Hope you wasn't hurt in the process.
01-15-2019, 10:37 AM | #15 |
Totally didnt see the bent fork tubes till now ... Damn!
