Old 06-27-2018, 08:00 PM   #1
Cekegren   Cekegren is offline
Doh! How to start taotao db10
I know nothing about dirt bikes. Bike just came and i assembled what needed to be put together. Now how do i start the damn thing!? Its an automatic with electic start and does nothing when i press the button. What am i missing here?
Old 06-27-2018, 08:14 PM   #2
humanbeing's Avatar
Originally Posted by Cekegren View Post
...an automatic with electic start and does nothing when i press the button...
Forget to charge the stock battery/ Ground wire lossen ....
If everything OK,try as start an automatic scooter (ie. pulled brake level to activities the s/W ... & start button at the SAME moment)
Old 06-28-2018, 12:53 AM   #3
starting db10
lack of info..... is the battery charged... squeeze the brake to start... check the fuse to see if it good... apply a brake.... you can always jump the solenoid... it should crank and fire... try that...
ABIBABA ATV ETC
Old 06-28-2018, 02:32 AM   #4
Gas? Spark? Battery, Kill switch on/off?
Old 06-28-2018, 07:21 PM   #5
Douglass   Douglass is offline
Douglass's Avatar
You may have to press the brake levers, and make sure the kill switch is in the run position. This is assuming the battery has a charge.
Douglass
battery, db10, start, tao, taotao
