06-14-2018, 05:48 AM | #1 |
Keeway TX 125 speedo problems
Hi all,
Have any of you come across a problem with a dead speedo? My son has bought a TX125 second hand and his is broken. The TX125 dashboard has an analog speedometer with a digital odometer and LED indicator lights. Most of the idiot lights work so there's power going to the PCB but the speedo and odometer are dead in the water. I did buy a second-hand sender unit, the bit that attaches to the front wheel, but that made no difference (although the replacement one might be broken, but how do I tell?) Wondered if anyone had come across this problem and found a solution, or hand some useful suggestions. Cheers, Parthe |
06-14-2018, 07:45 AM | #2 | |
06-14-2018, 07:53 AM | #3 | |
https://www.aliexpress.com/item/Spee...298918779.html https://www.aliexpress.com/item/Spee...ceBeautifyAB=0
06-14-2018, 09:42 AM | #4 |
Fit 1 of this http://www.chinariders.net/showthread.php?t=19680 & ride it
06-14-2018, 10:07 AM | #5 |
This would be a nice upgrade if you are good at figuring out the wiring. https://www.aliexpress.com/item/Moto...b3fd67293fc23c
06-14-2018, 11:55 AM | #6 |
The ultimate lazy approach. Zip tip or velcro this. https://www.amazon.com/Universal-Spe...ph+speedometer
and power it with one of these. https://www.ebay.com/itm/Waterproof-...72.m2749.l2649 Or get said USB charger above, buy a Ram Mount, and rock a GPS Speedometer app from your cell phone. I have a friend who does that on his old bike lol.
06-18-2018, 06:00 AM | #7 |
Thanks all for your responses. I do like the look of some of the after-market speedos but as I want to sell this onwards in a year or two I will go with JerryHawk250's links to the genuine Keeway replacements.
That said, if money is tight then the next person that asks this question could do well by going for: https://www.aliexpress.com/item/Moto...b3fd67293fc23c for the dashboard functions and replacing the headlamp with something else that does not have the shell for the Keeway speedo unit to fit in to. |
Tags |
keeway, speedometer, tx125 |
