Old 05-11-2017, 11:48 PM   #1
Wancsta   Wancsta is offline
Hawk or other 229cc engine based enduro setup database
I've seen these on other forums and looks like it would be helpful here with almost all of these needing some sort of tweaking out of the box. Post your setups here to help other CR's to spend more time riding than wrenching. If you are still having issues with your setup please wait to post until they are ironed out.
Bike: >>>Hawk, bashan, tt250 etc
Elevation:>>>Distance above sea level and location if you would like.
Carb:>>> Mikuni, PZ30, Keihin etc.
Jet sizes:>>> self explanatory
Needle setting :>>> Clip setting or shims used
Pilot screw turns:>>> self explanatory
Relevant mods:>>>Sprocket sizes, Exhaust, intake, bore, stroke, porting, cam? NOT lights, suspension, stickers etc
Top speed:>>> Please try to only put gps verified numbers here and specify if your going by that or the stock speedo.
BLANK
Bike:
Elevation:
Carb:
Jet sizes:
Needle setting:
Pilot screw turns:
Relevant mods:
Top speed:
Old 05-12-2017, 12:21 AM   #2
Bike: 2015 RPS Hawk
Elevation: 1100ft
Carb: PZ30
Jet sizes: 110 main, stock pilot
Needle setting: 2 shims
Pilot screw turns: 2
Relevant mods: air box mod, exhaust baffle removed, 17t front sprocket
Top speed: 56 (stock speedo)
Old 05-12-2017, 02:19 AM   #3
Bruce's   Bruce's is offline
Have you seen the internets hottest hawk ,Ariel ,BSA,norton mixed nonsense thread that has over 10 brazzilion viewers tuned in daily ,which has everything in the mods department listed dozens of times over and over ?,and I am pretty certain there is at least two threads compiling a list with which parts and mods are recommended for hawks although I cannot remember too many with the elevation listed .
Old 05-12-2017, 03:33 AM   #4
Yes I have. The purpose of this thread is to have an easy place to look at working setups without having to get through all the chatter and crosstalk. Maybe with enough people posting their info it can eventually be turned into a sticky.
-Jeff
Old 05-12-2017, 08:13 AM   #5
Bike: 2016 RPS Hawk
Elevation: 10ft
Carb: PWK30
Jet sizes: 125 main, 38 pilot
Needle setting: 2nd notch from bottom
Pilot screw turns:1 1/2
Direct Ignition Coil
Ported & Decked Head 10:1 Compression Ratio
Relevant mods: Foam Pod Filter, Ebay muffler, Cat removed, 17t front 40 rear sprocket, Dual oil coolers, NGK(2202) DPR8EIX-9 Iridium IX Spark Plug
Top speed: any day 76 mph GPS , Digital Cluster. fastest was 80 mph down hill lol
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 05-12-2017, 08:45 AM   #6
emptyschmitz   emptyschmitz is offline
emptyschmitz's Avatar
Bike: >>> Hawk
Elevation:>>> 600 Feet
Carb:>>> Mikuni VM26 Clone
Jet sizes:>>> 20 idle, 110 main
Needle setting :>>> Full Rich (lowest clip)
Pilot screw turns:>>> 1.5
Relevant mods:>>> 15/40 sprockets, stock exhaust, Airbox mod, stock air filter, Oil cooler
Top speed:>>> 55 mph GPS
2002 BMW R1100S, 1999 Kaw Concours, 1991 Kaw Eliminator 250, 1969 Honda Trail 90
Too many damn mopeds...
Old 05-12-2017, 12:01 PM   #7
Bike: 2007 Lifan GY5 200cc
Elevation: 100 feet
Carb: Mikuni 30mm
Jet Sizes: 109 main, 30 slow
Needle Setting: middle
Pilot Screw Turns: 1
Relevant Mods: 2002 XR250R muffler with 1996 XR250R tip (very little restriction), cat-free header
Top Speed: Not sure. Have reached at 70mph, but haven't actually held WOT for top speed. Cruise at about 62mph is reasonable
Old 05-12-2017, 03:07 PM   #8
Ariel Red Hunter's Avatar
Mixed nonsense? You know how to really hurt a guy!...ARH
Old 05-12-2017, 06:32 PM   #9
There is just too much other bike brand stuff and stories about your friends mixed in with that thread ,it is interesting reading for someone like me who has worked on Ariel square fours ,and bsa ,norton,laverda ,weirdo stuff like that ,but most people around here do not have the basics mastered ,and piling pages of info about bikes no longer relevant just makes for a bunch of unnecessary confusion .If you started a separate thread about your Ariel and your other adventures ,it would be easier for the novices to figure out what you are getting at ,and I think it would be more enjoyable to read for all .
I did note your thread was the internets hottest Hawk,......thread ,and made note of the 10 brazzilion viewers tuning in daily , I just feel if it stayed closer to the Hawk mother ship ,and the other stories stayed in a different thread it would be easier and less confusing .
Old 05-12-2017, 07:14 PM   #10
I didn't know that an Ariel Square Four was wierdo stuff, but I am always willing to be educated. Sorry you didn't find any useful stuff on Hawk Talk...ARH
Old 05-12-2017, 09:56 PM   #11
I didn't say or mean I didn't find anything useful , just that a new bike person ,new hawk owner if he read that thread which has more info about ariels ,and other bikes will find the information overwhelming .
As for the square four being weirdo stuff how can it not be ? Not a lot of motorcycle engines running around in the 30's with two crankshafts in one engine .
Old 05-13-2017, 01:39 PM   #12
Why do I bring up other bikes on Hawk Talk
To me, a single is a single - no matter who made it or when. I'll make it even easier, an air cooled single is much more like every other air cooled single, then you would think. And what has been found to work on any air-cooled single should work on the Hawk single. Within reason. The development of air-cooled singles has been going on since 1900. What works on one of them works on all of them. Getting a more dense volume of flammable gas into the cylinder, and out of it after we have gotten as much work out of it as possible. If the engine has rigid enough crankcases to stand the power increase. Which the Hawk has. The Hawk engine has a very nice die cast head with very good porting. The problems start with the air box, then to the tube which connects it to the carburetor, and the carburetor itself. Through the head, everything is OK. Then comes the exhaust system, which is awful. Bubble gum welds inside the pipe, some kind of rag gasket between head and pipe, tiny catalytic converter restricting flow even more. We've discussed carburetor tuning, and so forth....ARH
Old 05-14-2017, 09:08 PM   #13
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
Bike: 2016 CSC TT 250
Elevation: 13 feet
Carb: Stock Keima
Jet Sizes: 115 Main, Stock Pilot
Needle Setting: Raised 1 notch
Pilot Screw Turns: I haven't had time to drill out the plug for the pilot as of yet.
Relevant Mods: Opened up stock exhaust, 17/45 Gearing, swapped stock speedo for digital cluster.
Top Speed: I have reached 67 mph on GPS on a slight downhill which read 68 on the digital cluster. It will cruise at 60 mph with no problem.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18.
Old 05-19-2017, 11:42 AM   #14
rvl8rida   rvl8rida is offline
when you guys talk about shimming the needle, do you have the 5 available notches, you put it on the most rich setting, and also put a washer under that?
Old 05-19-2017, 11:45 AM   #15
The stock carbs don't have the grooves so we have to shim it.
2004 Honda ST 1300
