Old 08-24-2016, 11:20 AM   #1
katflap   katflap is offline
katflap's Avatar
Rx3 fault code look up prog
I've made a little program , for my self, for looking up the engine management fault codes.
You can input the flashing light (hex) codes and the PCHUD (dec) codes.
The example below shows the P031 code being entered.
The result gives a discription of the fault and where to find the relevant info in the included manual.
The included manual is for a large mower engine that shares quite a number of Engine management components as our RX3.
I do intend to test some of the values given in this manual when I get time.
For now please only use as a guide.
The program needs no installation, You just need to run it.
https://mega.nz/file/Ngs2hRaL#4bNsDC..._8ndVy2fuOF9nA
Update:-
Download now only contains the manual etc.
See post #8 for the code look up program
http://www.chinariders.net/showpost....85&postcount=8
Old 08-24-2016, 01:11 PM   #2
Katflap, you're an amazing resource to RX3 riders. Thanks for your contributions.
Old 08-24-2016, 04:45 PM   #3
i was going to say the same thing. amazing
however, some of the hat tricks human being has pulled on the tech information scale have been near incredible.
Old 08-26-2016, 01:06 PM   #4
katflap's Avatar
Testing The Manual part 1
Tested on an RX3 that is running well with no errors
In the manual It states, before doing anything else, to verify That the ECM is powering up.
The procedure is on page 49.
In the procedure it refers to the connector pins of the ECU, these can be found on page 38 & 39. The pins appear to be correctly labelled.
My results from following their procedure are -
Step 1, 12.94v (stated range 12.2v - 13.5v)
Step 2, 12.6v (stated range 12.2v - 13.5v)
Step 3, 0 ohms ( stated range below 2 ohms)
Step 4, 0 ohms ( stated range below 2 ohms)
J2-18, voltage comes directly from the battery
J2-15, voltage comes from the Ignition switch via the "engine run" switch.
This particular wire also provides the voltage to energize the fuel pump relay.
J2-2 & J1- 9 , go to ground.
this first test seems good
Old 08-27-2016, 02:07 PM   #5
katflap's Avatar
Testing The Manual part 2
Testing the procedure for P031/P032 , O2 voltage high/low (page 52-53)
Firstly, the O2 connector is labelled correctly
step2,
"use a test light", on page 14 it suggest to use a test light that draws no more than 0.3A, I found a bulb rated 3W for the job. It draws 0.26A.
It Illuminated as brightly as when connected directly to the battery.
(stated - Illuminates brightly)
step3,
12.16 v ( a bit low ) , (stated range 12.2-13.5v)
step4,
" connect to J2-17", this is not possible as it is plugged in to the ECU. I tested point "C" on the O2 sensor connector, it connects directly to "J2-17".
4.78v (stated range 4.20v- 4.95v)
step5,
4.74v (stated range 4.20v- 4.95v)
Old 09-01-2016, 10:38 AM   #6
katflap's Avatar
Testing the manual part 3
( pins are correctly labelled)
Testing the procedure for P0107 Map Sensor low voltage (page 54-55)
step2,
Cycled fault code P0108 & P0112 while running but when re assembled no current code remained.
step3,
4.96 v (stated range, above 4v)
Testing the procedure for P0108 MAP sensor high voltage (page 56)
step2,
Cycled fault code P0107 & P0112 while running but when re assembled no current code remained.
step3,
4.96v - (stated range, above 4v)
Testing the procedure for P0112 MAT sensor Low temp indicated (page 57 -58)
step2,
4.8v (stated range, above 4v)
step3,
4.94v (stated range, above 4v)
Testing the procedure for P0113 MAT sensor high temp indicated (page 59)
step2,
4.96v (stated range, above 4v)
Old 10-19-2016, 05:24 PM   #7
Kat,
As always, thanks for doing the great research, and sharing your knowledge with us.
I successfully downloaded the manual. However, my anti-virus software detected a trojan horse virus associated with the look up program.
Old 10-20-2016, 09:59 AM   #8
katflap's Avatar
Kat,
This will be a false-positive
A lot of antivirus programs are not too clever and will shout Trojan at every horse in town.
Here’s a link explaining a little about the problem in this instance.
http://www.hide-folder.com/overview/false-positive.html
Anyhoo, Nobody likes even a whiff of Trojan mentioned on their computer even if it is a false-positive, myself included.
My little program is just a visual basic script inside a “wrapper” that creates the “exe” file. The reason I put it inside a wrapper was , ironically , to help prevent it being tampered with by the wider web, where possibly some malicious script could be added.
It will work perfectly well without a wrapper but because a VBS script is vulnerable , on the wider web a “virus” script could be added and distributed as my work , I chose not to upload it in this format.
So the simple solution is for people to make it themselves , this is really easy to do
Requirements-
1/ Any computer running a version of Windows
2/ make sure you have file extensions visible.
Steps –
1/ Copy the script below to notepad
Code:
Title = "RX3 Delphi MT-O5 ECU FAULT CODE LOOK UP v2 - by katflap"
message = "FOR A GUIDE ON CONNECTIONS ETC SEE PAGES 38-46   _____________________________________  ENTER FAULT CODE BELOW (Numbers Only)"
 Question = InputBox(message,Title,Default)
Select Case Question
Case    1  msgbox ("katflaps Shed Productions !!!!")
Case  107  msgbox ("(P0107/263) MAP CIRCUIT - LOW OR OPEN VOLTAGE  (Location MAP/MAT - Next to injector)   As a guide see pages 54-56 (non scan diagnostics)- pages 97- 99 (scan diagnostics)")
 Case  108  msgbox ("(P0108/264) MAP CIRCUIT - HIGH VOLTAGE   (Location MAP/MAT - Next to injector)   As a guide see pages 54-56 (non scan diagnostics)- pages 97- 99 (scan diagnostics)")
 Case  112  msgbox ("(P0112/274) MAT CIRCUIT - LOW VOLTAGE  (Location MAP/MAT - Next to injector)   As a guide see pages 57-59 (non scan diagnostics)- pages 100- 102 (scan diagnostics)")
 Case  113  msgbox ("(P0113/275) MAT CIRCUIT - HIGH VOLTAGE OR OPEN   (Location MAP/MAT - Next to injector)   As a guide see pages 57-59 (non scan diagnostics)- pages 100- 102 (scan diagnostics)")
 Case  117  msgbox ("(P0117/279) COOLANT TEMP SENSOR CIRCUIT - LOW VOLTAGE (Location - thermostat housing- Blue connector)   As a guide see pages 60-62 (non scan diagnostics)- pages 103- 105 (scan diagnostics)")
 Case  118  msgbox ("(P0118/280) COOLANT TEMP SENSOR CIRCUIT - HIGH VOLTAGE OR OPEN  (Location - thermostat housing- Blue connector)   As a guide see pages 60-62 (non scan diagnostics)- pages 103- 105 (scan diagnostics)")
 Case  122  msgbox ("(P0122/290) TPS CIRCUIT - LOW VOLTAGE OR OPEN  (Location - See Throttle Body Image)  As a guide see pages 63-68 (non scan diagnostics)- pages 106- 111 (scan diagnostics)")
 Case  123  msgbox ("(P0123/291) TPS CIRCUIT - HIGH VOLTAGE   (Location - See Throttle Body Image)  As a guide see pages 63-68 (non scan diagnostics)- pages 106- 111 (scan diagnostics)")
 Case  131  msgbox ("(P0131/305) O2 SENSOR CIRCUIT - LOW VOLTAGE  (Location - Exhaust header pipe)  As a guide see pages 69-71 (non scan diagnostics)- pages 112- 114 (scan diagnostics)")
 Case  132  msgbox ("(P0132/306) O2 SENSOR CIRCUIT - HIGH VOLTAGE   (Location - Exhaust header pipe)  As a guide see pages 69-71 (non scan diagnostics)- pages 112- 114 (scan diagnostics)")
Case   32  msgbox ("(P0032/50) O2 HEATER CIRCUIT - HIGH VOLTAGE    (Location - Exhaust header pipe)    As a guide see pages 52-53 (non scan diagnostics)- pages 94- 96 (scan diagnostics)")
 Case   31  msgbox ("(P0031/49) O2 HEATER CIRCUIT - LOW VOLTAGE   (Location - Exhaust header pipe)    As a guide see pages 52-53 (non scan diagnostics)- pages 94- 96 (scan diagnostics)")
 Case  201  msgbox ("(P0201/513) INJECTOR CIRCUIT MALFUNCTION   As a guide see pages 73-74 (non scan diagnostics)- pages 116- 117 (scan diagnostics)")
 Case  230  msgbox ("(P0230/560) FUEL PUMP RELAY CIRCUIT - LOW OR OPEN VOLTAGE   As a guide see pages 75-81 (non scan diagnostics)- pages 118- 122 (scan diagnostics)")
 Case  232  msgbox ("(P0232/562) FUEL PUMP RELAY CIRCUIT - HIGH VOLTAGE  As a guide see pages 75-81 (non scan diagnostics)- pages 118- 122 (scan diagnostics)")
 Case  336  msgbox ("(P0336/822) CRANK SHAFT POSITION SENSOR - NOISEY SIGNAL  As a guide see pages 82-83 (non scan diagnostics)- pages 123- 124 (scan diagnostics)")
 Case  337  msgbox ("(P0337/823) CRANK SHAFT POSITION SENSOR - NO SIGNAL  As a guide see pages 82-83 (non scan diagnostics)- pages 123- 124 (scan diagnostics)")
 Case  351  msgbox ("(P0351/849) IGNITION COIL MALFUNCTION  As a guide see pages 84-85 (non scan diagnostics)- pages 125- 126 (scan diagnostics)")
 Case  505  msgbox ("(P0505/1285) IDLE AIR CONTROL VALVE ERROR (PCHUD)  (Location - See Throttle Body Image)  As a guide see pages 86-87 (non scan diagnostics)- pages 127-128 (scan diagnostics) ")
 Case  562  msgbox ("(P0562/1378) SYSTEM VOLTAGE LOW    As a guide see pages 88-89 (non scan diagnostics)- pages 129-130 (scan diagnostics)")
 Case  563  msgbox ("(P0563/1379) SYSTEM VOLTAGE HIGH   As a guide see pages 88-89 (non scan diagnostics)- pages 129-130 (scan diagnostics)")
 Case  650  msgbox ("(P0650/1616) FAULT LIGHT CIRCUIT MALFUNCTION   As a guide see pages 90-91 (non scan diagnostics)- pages 131-132 (scan diagnostics)")
 Case 1693  msgbox ("(P1693/5779) TACHOMETER CIRCUIT LOW VOLTAGE")
 Case 1694  msgbox ("(P1694/5780) TACHOMETER CIRCUIT HIGH VOLTAGE")
 Case  171  msgbox ("(P0171/369) HIGH MAXIMUM ADAPTION LIMIT EXCEEDED   As a guide see code 0171 text")
 Case  172  msgbox ("(P0172/370) LOW MAXIMUM ADAPTION LIMIT EXCEEDED    As a guide see code 0172 text")
 Case  174  msgbox ("(P0174/372) LEAN FUEL CONDITION   As a guide see page 72 (non scan diagnostics)  page 115  (scan diagnostics) ")
 Case  850  msgbox ("(P0850/2128) GEAR POSITION SENSOR OR CLUTCH SWITCH CIRCUIT MALFUNCTION")
 Case   61  msgbox ("(P0061/97) END OF FAULT CODE TRANSMISSION")
 Case  263  msgbox ("(P0107/263) MAP CIRCUIT - LOW OR OPEN VOLTAGE (PCHUD)  (Location MAP/MAT - Next to injector)   As a guide see pages 54-56 (non scan diagnostics)- pages 97- 99 (scan diagnostics)")
 Case  264  msgbox ("(P0108/264) MAP CIRCUIT - HIGH VOLTAGE (PCHUD)  (Location MAP/MAT - Next to injector)   As a guide see pages 54-56 (non scan diagnostics)- pages 97- 99 (scan diagnostics)")
 Case  274  msgbox ("(P0112/274) MAT CIRCUIT - LOW VOLTAGE (PCHUD) (Location MAP/MAT - Next to injector)   As a guide see pages 57-59 (non scan diagnostics)- pages 100- 102 (scan diagnostics)")
 Case  275  msgbox ("(P0113/275) MAT CIRCUIT - LOW VOLTAGE (PCHUD) (Location MAP/MAT - Next to injector)   As a guide see pages 57-59 (non scan diagnostics)- pages 100- 102 (scan diagnostics)")
 Case  279  msgbox ("(P0117/279) COOLANT TEMP SENSOR CIRCUIT - LOW VOLTAGE  (PCHUD) (Location - thermostat housing- Blue connector)   As a guide see pages 60-62 (non scan diagnostics)- pages 103- 105 (scan diagnostics)")
 Case  280  msgbox ("(P0118/280) COOLANT TEMP SENSOR CIRCUIT - HIGH VOLTAGE OR OPEN (PCHUD) (Location - thermostat housing- Blue connector)   As a guide see pages 60-62 (non scan diagnostics)- pages 103- 105 (scan diagnostics)")
 Case  290  msgbox ("(P0122/290) TPS CIRCUIT - LOW VOLTAGE OR OPEN  (Location - See Throttle Body Image)  As a guide see pages 63-68 (non scan diagnostics)- pages 106- 111 (scan diagnostics)")
 Case  291  msgbox ("(P0123/291) TPS CIRCUIT - HIGH VOLTAGE   (Location - See Throttle Body Image)  As a guide see pages 63-68 (non scan diagnostics)- pages 106- 111 (scan diagnostics)")
 Case  305  msgbox ("(P0131/305) O2 SENSOR CIRCUIT - LOW VOLTAGE  (PCHUD)  (Location - Exhaust header pipe)  As a guide see pages 69-71 (non scan diagnostics)- pages 112- 114 (scan diagnostics)")
 Case  306  msgbox ("(P0132/306) O2 SENSOR CIRCUIT - HIGH VOLTAGE  (PCHUD)  (Location - Exhaust header pipe)  As a guide see pages 69-71 (non scan diagnostics)- pages 112- 114 (scan diagnostics)")
 Case   50  msgbox ("(P0032/50) O2 HEATER CIRCUIT - HIGH VOLTAGE (PCHUD)  (Location - Exhaust header pipe)   As a guide see pages 52-53 (non scan diagnostics)- pages 94- 96 (scan diagnostics)")
 Case   49  msgbox ("(P0031/49) O2 HEATER CIRCUIT - LOW VOLTAGE (PCHUD)  (Location - Exhaust header pipe)    As a guide see pages 52-53 (non scan diagnostics)- pages 94- 96 (scan diagnostics)")
 Case  513  msgbox ("(P0201/513) INJECTOR CIRCUIT MALFUNCTION (PCHUD)   As a guide see pages 73-74 (non scan diagnostics)- pages 116- 117 (scan diagnostics)")
 Case  560  msgbox ("(P0230/560) FUEL PUMP RELAY CIRCUIT - LOW OR OPEN VOLTAGE  (PCHUD)   As a guide see pages 75-81 (non scan diagnostics)- pages 118- 122 (scan diagnostics)")
 Case  562  msgbox ("(P0232/562) FUEL PUMP RELAY CIRCUIT - HIGH VOLTAGE  (PCHUD)  As a guide see pages 75-81 (non scan diagnostics)- pages 118- 122 (scan diagnostics)")
 Case  822  msgbox ("(P0336/822) CRANK SHAFT POSITION SENSOR - NOISEY SIGNAL  (PCHUD)  As a guide see pages 82-83 (non scan diagnostics)- pages 123- 124 (scan diagnostics)")
 Case  823  msgbox ("(P0337/823) CRANK SHAFT POSITION SENSOR - NO SIGNAL  (PCHUD)  As a guide see pages 82-83 (non scan diagnostics)- pages 123- 124 (scan diagnostics)")
 Case  849  msgbox ("(P0351/849) IGNITION COIL MALFUNCTION  (PCHUD)  As a guide see pages 84-85 (non scan diagnostics)- pages 125- 126 (scan diagnostics)")
 Case  1285  msgbox ("(P0505/1285) IDLE AIR CONTROL VALVE ERROR (PCHUD)  (Location - See Throttle Body Image)  As a guide see pages 86-87 (non scan diagnostics)- pages 127-128 (scan diagnostics) ")
 Case 1378  msgbox ("(P0562/1378) SYSTEM VOLTAGE LOW  (PCHUD)   As a guide see pages 88-89 (non scan diagnostics)- pages 129-130 (scan diagnostics)")
 Case 1379  msgbox ("(P0563/1379) SYSTEM VOLTAGE HIGH  (PCHUD)  As a guide see pages 88-89 (non scan diagnostics)- pages 129-130 (scan diagnostics)")
 Case 5779  msgbox ("(P1693/5779) TACHOMETER CIRCUIT LOW VOLTAGE (PCHUD)")
 Case 5780  msgbox ("(P1694/5780) TACHOMETER CIRCUIT HIGH VOLTAGE (PCHUD)")
 Case  369  msgbox ("(P0171/369) HIGH MAXIMUM ADAPTION LIMIT EXCEEDED (PCHUD)  As a guide see code 0171 text")
 Case  370  msgbox ("(P0172/370) LOW MAXIMUM ADAPTION LIMIT EXCEEDED  (PCHUD)  As a guide see code 0172 text")
 Case  372  msgbox ("(P0174/372) LEAN FUEL CONDITION (PCHUD)   As a guide see page 72 (non scan diagnostics)  page 115  (scan diagnostics)")
 Case 1616  msgbox ("(P0650/1616) FAULT LIGHT CIRCUIT MALFUNCTION  (PCHUD)   As a guide see pages 90-91 (non scan diagnostics)- pages 131-132 (scan diagnostics)")
 Case 2128  msgbox ("(P0850/2128) GEAR POSITION SENSOR OR CLUTCH SWITCH CIRCUIT MALFUNCTION (PCHUD)")
 Case   97  msgbox ("(P0061/97) END OF FAULT CODE TRANSMISSION")
Case Else  msgbox ("Try Again, Dude - Code Not Found")
 end Select
2/ save the notepad file with the name of your choice and close it.
3/ rename the extension of your new notepad file from .txt to .vbs
4/ then just "click" your new "vbs" file to use
Old 10-20-2016, 01:53 PM   #9
Thank you, Kat. I just followed your instructions, which took 5 minutes or less to complete, and the program is working great.
Old 08-01-2019, 01:22 PM   #10
juanoikos   juanoikos is offline
good afternoon
I would like you to help me with the Software to read the error codes of my Zongshen RX3.
Old 08-12-2021, 11:24 PM   #11
ChopperCharles   ChopperCharles is offline
ChopperCharles's Avatar
So, what does a P0132 error code actually mean? Bad O2 sensor? Or something else?
Charles.
Old 08-13-2021, 12:17 AM   #12
Working_ZS   Working_ZS is offline
Charles.
It simply means that the output voltage from the O2 sensor has been too high for too long. In normal operation, an O2 sensor continually swings back and forth between .1 - .9 volts. P0132 means that yours isn't varying, staying at a high voltage reading.
Old 08-13-2021, 09:36 AM   #13
Right right. But what does this diagnosis mean? Bad 02 sensor or bad maf/mat or something else?
Bike was running lean, not rich. Big flat spots. But then it was idling at 2500-3000rpm.
Charles.
Old 08-13-2021, 07:09 PM   #14
Charles.
It means exactly what it means, nothing more and nothing less. I know, not super helpful, but you have to take these things exactly at face value.
In your case, the O2 sensor is outputting a high voltage, what voltage exactly I can't say without a multimeter or an oscilloscope, but definitely more than .5 volts if I had to guess, since .45 indicates an "ideal" combustion mixture. This could be because the bike is genuinely running rich, which causes the O2 sensors to output more voltage, thereby signaling the ECU to subtract fuel via the short term and long term fuel trims. If so, that could be causing your lean condition and weird high idle. No way to know for sure until you get your diagnostic stuff, set it up, link up to the bike, and see what the ECU has to say. I just received mine yesterday, by the way. I haven't had the ambition to work out in the garage due to the heat and humidity, so I can't say yet whether or not it actually works. I also need to get one of my old Windows 7 netbooks upgraded to Windows 10, so that I can run the diagnostic software.
When you get yours up an running, the HUD ECUHacker software will come in very handy, since it will display those data PIDs mentioned, allowing you to see exactly what the ECU is seeing, which will help you decypher what is going on. When you link up, check the short and long term fuel trims - yours should be negative if the ECU is seeing a rich condition from the O2 sensor. Also, look at you MAP sensor values, since manifold pressure is used as a surrogate for engine load; high vacuum, which occurs at idle, causes a low MAP sensor signal to the ECU, which will in turn cut fuel, since the engine is not under load.
Note: A vacuum leak can throw off the MAP signal, so be sure to check for intake manifold and throttle body vacuum leaks before you go and condemn your existing MAP sensor as bad.
Old 08-13-2021, 08:25 PM   #15
I already waved an unlit propane torch around the intake, with no change in behavior. One of those big brush-clearing torches. It's enough propane to stop an EX500 motor in under a second when waved around the airbox intake. And nothing budged on my RX3.
Charles.
