Old 04-15-2015, 08:03 PM   #1
octometh   octometh is offline
Head Scratching 2004 Flywing Transmission Flows Oil
So I was on a ride when my chain came off. One of the links faces broke off so I just stuck it back on and rode careful. After a few minutes the chain popped off and I guess it hit the side of the transmission and now oil leaks out after 5-10 seconds of running. Anyone have any idea how I might even begin to fix this?
Old 04-15-2015, 09:28 PM   #2
humanbeing's Avatar
http://www.advrider.com/forums/showthread.php?t=433683
Old 04-16-2015, 01:36 AM   #3
I would try the epoxy options from the link that HB provided. Quick Steel or Tech Steel have a texture more like putty, so you can actually mold it into place.
Old 04-16-2015, 01:13 PM   #4
I have JB weld but I have a piece that covers about half the hole so I can't imagine trying to get JB weld to cover across that entire thing.The stator/flywheel protector got pretty destroyed too. You think it would work on that also? I believe its all aluminium so do I need to get the quick aluminium epoxy instead of quick steel? Thanks for your help this is my first bike.
Old 04-16-2015, 03:53 PM   #5
humanbeing's Avatar
Originally Posted by octometh View Post
...The stator/flywheel protector got pretty destroyed too...
I don't believe those quick... Get the decent stuff that needs mixing by urself,
Good chinese stuff...
Similar to original 2-tube JB weld http://item.taobao.com/item.htm?id=38908186703
The "putty" for BiG job http://item.taobao.com/item.htm?id=38007450170
http://item.taobao.com/item.htm?id=17280935222
For DEEP wallet :Honda # 11341-KCS-650
Old 04-16-2015, 04:26 PM   #6
Wow $8.07 with shipping. I don't know how legit this is but I guess I might try it... Last question. Does anyone know what this particular part is(the part in the picture)? What point does the oil coming from the top and in the hole serve?
Old 04-16-2015, 09:04 PM   #7
humanbeing's Avatar
You may also ask "alex_in_az" http://www.chinariders.net/showthrea...t=13667&page=3 sell u that 125 machine.
You had ALL the stuff from MX to mod that 125...
Old 04-23-2015, 07:03 PM   #8
Anyone have any idea what this part is?
2004 Flywing
flywing., transmission
