Old 11-10-2013, 11:53 PM   #1
Wild_Alaskan's Avatar
I guess I'm a china rider again
Just picked up a rocketa 110 for $120 today. Going to be swapping an lifan 125 engine i have laying around in to it soon since I am pretty sure this one is based off of the crf50. Ill get some pictures tomorrow.
Old 11-11-2013, 12:26 AM   #2
Good for you!
Old 11-11-2013, 08:09 AM   #3
katoranger's Avatar
You back to Montana now? The engine should be an easy swap for you.
Old 11-11-2013, 11:21 AM   #4
He could probably do it over dinner and a beer.
Old 11-11-2013, 11:36 AM   #5
yep back in montana
Old 11-11-2013, 12:20 PM   #6
Is it a pit bike? What size are the wheels?
Old 11-11-2013, 12:36 PM   #7
yeah its a pit bike, not sure but I would guess the wheels are 10"
Old 11-11-2013, 01:15 PM   #8
You will have a lot of fun running around on that.
Old 11-11-2013, 07:12 PM   #9
Here are some pictures, I belive I have this model of bike
http://www.roketa.com/product/produc...D=0&proID=2069
mine has a 12" 10" tire setup though.
I got the lifan engine mostly installed but somehow misplaced my new carburetor, hopefully i can finish tomorrow.
Old 11-11-2013, 11:40 PM   #10
That puppy should move with a 125cc engine in it. We eagerly await additional photos.
Old 11-12-2013, 05:38 PM   #11
Finished up the motor install today, It not running perfectly yet but moves right along for a pit bike. Going to work on the jetting soon.
Needed to make a little bit of clearance for the carburetor, otherwise the transition was really smooth
Old 11-12-2013, 08:00 PM   #12
Nice work! How did you cut the cooling fins?
Old 11-13-2013, 02:44 PM   #13
i was going to grind them down with my angle grinder but it was in storage so i ended up using a chisel instead, actually came out really good
Old 11-13-2013, 02:53 PM   #14
katoranger's Avatar
The Chinese would have used the same tools at the factory.
Old 11-13-2013, 07:27 PM   #15
Fixed my poor running today, I replaced the wiring harness with the one that came with the motor, the other one must have had a short which explains why both motors initially had the same running issues.
