Old 05-09-2024, 12:15 PM   #16
Dusman   Dusman is offline
Orion RXB 190L
The Orion RXB 190L is about as close as you can get to what you’re looking for, but again, it’s the 5 speed ZS190 engine, not a 6 speed. It’s street legal and powerful (@ 16HP stock; some say 18) and only 178lbs, but again, it’s street legal pit bike with a dirt bike seat and essentially what is a racing engine. ZS190 engines are known to be higher maintenance and finicky (i.e., starter chains breaking).
Old 05-09-2024, 06:08 PM   #17
Zapkin   Zapkin is offline
Zapkin's Avatar
I can't help but think that if you consider how much work is actually done for the amount of fuel consumed, they are all incredibly inefficient. Is that a fair statement?
2022 Hawk 250
Old 05-09-2024, 08:50 PM   #18
Not sure to what you'd compare it to.
If you compare it to a roketa mc 05 127, or a Grom, both getting well over 100mpg, any bike will look poor in comparison. The first bike being geared very aggressively for higher mpg/lower rpm per mph.
The Vader 150 is quite poor in it's gas mileage. Granted, I ride it at 6k rpm most of the time, and get a solid 60mpg out of it, while it gets closer to 80mpg when keeping it between 3 and 5k rpm.
This engine should be able to do 100mpg easily at 40-45mph (doing ~ 4k rpm.
A lot of the China bikes have lower performance when they're:
a- Air cooled, and,
b- not fuel injected.
Mainly because they'll run a pretty low compression ratio.
If there was only an easy way to increase compression ratio on pushrod engines... Especially people in colder regions will benefit from this (higher gas mileage, same or better performance).
Old 05-25-2024, 10:06 PM   #19
Seems like another contender (5spd) is the magician 250.
Old 05-25-2024, 10:20 PM   #20
XLsior   XLsior is offline
XLsior's Avatar
there are reports of 100cc bikes in India getting 100kmpl/235mpg.
But that's India. I can't say the models off the top of my head but that 100cc segment is cutthroat over there...
You would not be going particularity fast by western standards.
Old 05-26-2024, 09:37 AM   #21
Yeah. First. Like with a lot Asian, numbers need to be taken with a grain of salt. Second, they're probably in British mpg, which is like 33% higher rated.
A 4 stroke carbureted bike, ideally reaches up to 120, and that's with heavy overgearing. Fuel injected bikes can reach up to 150mpg, because they can lean out the mixture so much when power isn't needed and load is low.
So, reaching 200+mpg, may be possible on a mountain trail downhill.
Old 05-26-2024, 02:08 PM   #22
J4Fun   J4Fun is offline
I was looking at this bike too. It seems very nice and by the pictures I’ve seen the seat looks more cushy? My problem is it’s coming from a Texas dealer but says they state on the mco motorcycle. They might be a more powerful, more comfortable bike that looks like our Storm 150 DLX. And I noticed the seat height is lower. Why isn’t it the big seller? Would be curious to hear from others about that higher maintenance problem! I know a bit more expensive too. My thoughts…
Old 05-27-2024, 02:49 PM   #23
Ok since no response I assume it’s the problems that I’ve seen on YouTube about this bike. Shucks this looked like it would be a great bike
Old 05-27-2024, 06:22 PM   #24
XLsior's Avatar
https://www.chinariders.net/showthread.php?t=33943
Old 05-27-2024, 07:07 PM   #25
Orion Powersports RXB 190L Long boring pissy rant, on You Tube from Joe B. is what I was thinking when I posted.
Old 05-27-2024, 07:48 PM   #26
XLsior's Avatar
Seems decent enough. There are some quirks with the ZS190 that should be addressed.
The starter chain is typically shipped dry and can snap.
The shift star cog has a habit of popping off and should be looked at.
But otherwise seems like on ok 'big pitbike' for the street.
I would look for a vertical engine frame alternative though as this will open up far more engine upgrade options...
horizontal engines have their place...So if its a platform you prefer then realize the zs190 is about the peak with racing options squeezing a little more...
https://www.orionpowersports.com/ori...embled-tested/
Old 05-27-2024, 09:33 PM   #27
Originally Posted by LakeGastonHank View Post
I purchased the TrailMaster tm38ex, assembled it with no problems and it is an excellent, lightweight dual sport bike. I am currently looking for a smaller rear sprocket (Help anyone?) for it. The 51 tooth stock limits top speed to 65mph at redline. I want something like 47 tooth and it should be excellent on road. I did change tires from the MX only to a pair of Tusk dual sport tires and love them. I have the part number but can find no one who can order it.
The Templar X and Trailmaster TM38 (non-EX) fit JTR210 sprockets. Maybe yours as well. Here is the info:
https://www.jtsprockets.com/catalogue/sprocket/JTR210/
You can see if this matches the boltpattern on your EX.
Old 05-28-2024, 06:50 AM   #28
I just looked at the KLR250 and the XT250, and wonder if, and how much better their performance is than the Chinese bikes?
Old 05-28-2024, 07:08 AM   #29
zero_dgz   zero_dgz is offline
A buddy of mine has the previous RXB150L. The MCO did indeed say "motorcycle." It should theoretically be street legal but my state gave him some static over not coming with a chain guard from the factory and it also arrived without a license plate mount or plate light, both of which we had to fabricate. That wasn't too tough.
The seat is a plank. You may as well ride it standing up, or you should invest in a pair of those padded undershorts for bicyclists.
The reason it's not a big seller is probably because, for the 150 at least, it is comically tiny for adult riders and is also geared/powered so that it maxes out at a screaming 45 MPH. It is also very squirrely on pavement above 40. It is not fast enough to be safe to ride on anything but neighborhood streets in wide swathes of the US, where if you are not capable of doing 65+ MPH at the drop of a hat you will be run over or blown into the weeds by a raging Karen in an Escalade.
Old 05-28-2024, 09:54 PM   #30
I figured, a Japanese 125 equals a Chinese 150, and a japanese 150 equals a Chinese 250.
Even most Chinese 250s have trouble reaching 70mph, while my Honda rebel 250 could top out at just over 90 indicated (past the speedo max) under ideal conditions, but still wasn't good enough for highways in my opinion.
Especially not with a headwind, when it would slow down to a measurly 60-65mph.
