Old 07-11-2022, 01:25 PM   #1
Front Wheel Bearings - Question
Hi all,
Heard a crunching noise on my XPro Titan DLX front wheel and determined it to be the wheel bearings. I attached a pic which was taken after the dust cover was removed. I tried to pop out the bearing "case" from either side using a flathead screwdriver and mallet but they wouldn't budge. I then tried to pry off the rubber ring insert and that came out easily to expose a bearing ring that appears deformed and broken. I've never replaced bearings before but ordered these ones.. my question is.. does the assembly itself pop out and if so, how? or do i just replace the inner bearing ring?
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 07-11-2022, 01:43 PM   #2
herbie   herbie is offline
If you can’t get to the race from the other side then they do make expander tools for pulling bearings out but if your frugal like me you make one. I just replaced both front and rear wheel bearings on my goldwing. If you have a bolt laying around close to the diameter of the axle then cut a split in the bolt. Slide the bolt through the bearing and insert a punch or beatable screwdriver into the split and it grabs the bearing and pulls it out. I can take a picture of it when I get home if you like.
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 07-11-2022, 01:57 PM   #3
Ah, thanks for that advice! I also did a google search on the method and read that you can use a long screwdriver as i did and from opposite side catch the inner bearing and then beat on it in a balanced manner, ie.. hit the top edge and then the bottom edge so it comes out flat.. i think i can try that next.. banging just one edge will make it want to angle out and cause more damage im sure
2019 Beta 430 RRS
Old 07-11-2022, 02:12 PM   #4
I think the other sucky thing to add is that this happened at the 1k mile mark on the bike, so premature.. hopefully the aftermarket ones last longer
2019 Beta 430 RRS
Old 07-11-2022, 02:17 PM   #5
If you can get to then absolutely tap it out a little on each side until it comes out. I’ve never heard of the brand that you ordered, hopefully they are good. All balls brand bearings have been around a long time and most people love them. Since they are Chinese bearings the price is usually pretty good
1978 Kawasaki KL250
Old 07-11-2022, 03:31 PM   #6
The factory bearings, like most cheap bearings you find online, come with almost zero grease in them. That is why we recommend to either replace the bearings or remove the seal on the bearings and pack your own grease in them.
Old 07-11-2022, 03:36 PM   #7
Hmm.. so these ones i ordered say they are pre-lubricated with standard grease (see below).. do you think i should meddle to remove the seal and grease still? Also guaranteed for 6 months.
https://www.amazon.com/gp/product/B0...ustomerReviews
Main information
Product number: 6202-2RS
Packing quantity: 2 Pcs
Exterior design: Double rubber seals
Precision grade: ABEC-3
Lithium grease range: -30°C ~ +110°C
For size, speed and load, please see picture 2 above
Bearing type: Rolling bearings / ball bearings / single row deep groove ball bearings / chrome steel / Standard grease filling.
2019 Beta 430 RRS
Old 07-11-2022, 06:36 PM   #8
I have always bought Timken roller bearings. They are slightly more expensive, but they make 'em all. They have 6202-2RS. Description on ebay:
(2 PACK) TIMKEN 6202-ZZ 15X35X11MM Double Metal Seal Ball Bearings
$15 and free shipping.
The ones you got should certainly last longer than your OEM bearings, but if you ever have to replace THEM (!)...
Old 07-11-2022, 07:00 PM   #9
This is what I used to pull my wheel bearings out with, worked great
1978 Kawasaki KL250
Old 07-11-2022, 09:07 PM   #10
Buy good brand bearings and spend the extra dollars. Timken, nachi, skf, fag, or even all balls.
Old 07-12-2022, 08:43 AM   #11
Main information
These could last a long time. I am not familiar with Xike, but the warantee is a good sign. Just don't push them in on the inner race. Use a socket or something that matches up with the outer race and tap in place with a mallet or piece of wood.
Old 07-23-2022, 05:07 PM   #12
So I installed the new ones but unfortunately seem to have lost the inner hub spacer. I will be replacing the bearings once I get the inner spacer but does anyone know the specs for it. I know the inner diameter should be 15mm but not sure the length. This is on a 21" wheel for Xpro Titan. Any help is greatly appreciated. Thanks
2019 Beta 430 RRS
