Old 02-05-2020, 10:28 AM   #16
justin1328   justin1328 is offline
justin1328's Avatar
So another update and quick question. Took my Rhino out yesterday for a quick ride, it was a beautiful 65 F day. Quad was bogging out 1/4 - 3/4 throttle. It was running great on Sunday when it was 40 F outside. I am assuming I am now running too rich. So is this related to the air / mix screw? Should I down size main jet from a 115 to 110? or should I adjust the needle position? up or down? And as always, thanks in advance for the help.
Old 02-05-2020, 11:35 AM   #17
dragonbusa   dragonbusa is offline
No that wont help, its called an idle air mixture screw. Its not going to effect off idle performance.
Old 02-05-2020, 12:13 PM   #18
justin1328's Avatar
So I am not referring to the idle / air screw on the side, but rather the air mixture screw on the bottom, this is a Mikuni clone that has an additional screw on the bottom.
Old 02-05-2020, 01:03 PM   #19
bogieboy   bogieboy is online now
bogieboy's Avatar
that is the idle air mix screw. the one on the side is your idle speed screw, which adjusts the height of the slide for idle speed.
Old 02-05-2020, 02:45 PM   #20
justin1328's Avatar
Well, Then I'm learning a thing or two here. Thank you. That said, the idle seems to be fine, so I am guessing its the jetting or the needle position??
Old 02-05-2020, 07:38 PM   #21
Darth Racer's Avatar
Check an make sure your choke cable is working the full movement of the clutch... thinking it might not be opening all the way.
Yeah if need be before changing jets try going up or down one notch on the needle and test it out
Old 02-06-2020, 10:11 AM   #22
justin1328's Avatar
Thanks Darth!
Old 02-11-2020, 11:59 AM   #23
There's the key. Here's a brief summary:
- The slow jet is the basis for idle
- The pilot mixture screw is responsible for the transition from the slow jet to the main circuit. If the pilot mixture screw requires more than two turns out, the slow jet is too small. Ideal adjustment is found when you have a smooth throttle from idle.
- The jet needle in the slide is responsible for mid-range. As you open the throttle, the needle jet (directly above the main jet) is slowly uncovered by the tapered jet needle. Raising or lowering the jet needle affects how quickly or slowly the main jet comes on fully.
- When you're at WOT, it's all main jet in theory. The rest of the story is that the slow jet is still contributing fuel, but that's not important here.
If you move the clip up on the jet needle, you'll lift the slide later, which delays the onset of the main jet (that leans out the mid-range). Move the clip only one groove, reassemble and test; does it get better or worse?
Old 02-12-2020, 04:57 PM   #24
justin1328's Avatar
Weldangrind Thank you. I was aware of some of those principles; however, I have read that some guys swap out jets simply to adjust for ambient temp and altitudes. I am guessing that these guys are hardcore racers and need every ounce of edge they can get..... Not so much for a recreational Rhino In my case, it was the choke not opening all the way because of the way I had the choke rigged after installing the new carb. Non the less, I certainly learned a thing or two about these carbs in the process, and to me that is half the fun.. Thanks again sir.
250, carb, rhino, settings
