Thread Tools Display Modes
Old 12-10-2011, 08:50 PM   #181
katoranger's Avatar
I will probably just replace the starter. $50 and be done.
Modules are available for $25. Multiple issues, but it still runs.
Old 12-12-2011, 02:32 PM   #182
katoranger's Avatar
I just bought a new ignition module for $10 on ebay. It won't hurt to replace it since they are known weak points.
Will have to stop and pick up a new starter at some point too.
Old 12-12-2011, 02:39 PM   #183
Nice score, Allen!
Old 12-12-2011, 08:47 PM   #184
New to you, or NOS?
Old 12-13-2011, 08:45 AM   #185
katoranger's Avatar
NOS. Still in the box. I need to go find the little socket that I bought for the last one.
Old 12-13-2011, 10:42 AM   #186
That's an amazing price! Good score.
Old 12-29-2011, 12:41 PM   #187
katoranger's Avatar
New TFI installed. Nothing changed there that I noticed yet. I just replaced the starter drive. It was $16. Problem seems to be solved. Took less than an hour.
Old 12-29-2011, 03:30 PM   #188
That's wonderful! Thanks for the update, Brother Allen.
Old 12-30-2011, 09:11 AM   #189
katoranger's Avatar
I need to fix all the oil leaks next. Front and rear seals, oil pan gasket, and valve cover all leak.
Old 01-01-2012, 01:29 PM   #190
If you're gonna go to that level of effort, it would also pay to clean the pickup and pan. No sense in plugging up the pump and starving the bearings after changing all of the seals.
Old 01-01-2012, 09:07 PM   #191
katoranger's Avatar
That is a good idea. It may be that I go as far as a rebuild. Plan to perform some tests. I think that the compression may be on the low side.
Old 01-02-2012, 01:01 PM   #192
When I'm at that crossroad, I usually buy another engine and rebuild it on the stand. Once it's done, I then swap them in a weekend. That plan allows you to really take your time and shop around for parts, not to mention pay attention to all of the details.
Old 01-02-2012, 06:25 PM   #193
katoranger's Avatar
I am casually watching for a replacement. I agree that would be the best solution. Not sure how much work it would be to swap to a newer 2.3l with the DIS ignition and roller cams. They have a bit more power.
Old 01-02-2012, 07:10 PM   #194
If I was swapping to something different, I'd choose a 3.0 with a 5 speed. They're cheap, plentiful, torquey and easy on fuel. You could easily find one that does not require rebuilding.
Old 01-02-2012, 08:33 PM   #195
katoranger's Avatar
That might be a maybe. Probably stick the original setup with the roller cam out of the newer 2.3l and maybe some larger injectors. That might wake it up alittle.
